Chrome polish for spoke wheels
by gman2304
07/02/16 01:52 AM
'09 Nissan Sentra-Eni i-Sint XL 4AM 5w-30-10k.
by montero1
07/02/16 01:11 AM
Questions about manual transmission sounds
by Why_Anything
07/01/16 11:09 PM
HOW to learn PINSTRIPING & lettering ??
by SumpChump
07/01/16 11:08 PM
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
07/01/16 11:00 PM
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
07/01/16 10:38 PM
new Tundra color
by lawnman
07/01/16 10:36 PM
Bought A Yamaha XSR900 today!
by donnyj08
07/01/16 10:21 PM
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
07/01/16 10:08 PM
Replace oxygen sensor by mileage ?
by Merkava_4
07/01/16 10:02 PM
I was slightly wrong on the Purolator transition
by slacktide_bitog
07/01/16 09:57 PM
Things your dogs have eaten.....
by OVERKILL
07/01/16 09:45 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
31 registered (bobt2382, Blkstanger, bdcardinal, chrisri, 3 invisible), 861 Guests and 17 Spiders online.
58341 Members
66 Forums
251131 Topics
#1971410 - 07/31/10 05:34 PM MMO increases or decreases octane rating
jsap Offline
Loc: NorCal
Does MMO increase or decrease octane rating of gasoline?
Beware of stealers
#1971414 - 07/31/10 05:38 PM Re: MMO increases or decreases octane rating [Re: jsap]
Boomer Offline
Loc: Pennsylvania
Most oily substances are linear hydrocarbons, statiscally speaking, and would therefore be of low octane rating. So I would put MMO in that category. However, if you follow the manfacturer's recs, it should not have a large affect.
2003 Saturn L 300 128,200 miles
2013 VW Passat TDI SE, 33,300 miles
2014 VW Jetta TDI SportWagen 17,500 miles
#1971417 - 07/31/10 05:42 PM Re: MMO increases or decreases octane rating [Re: Boomer]
Lethal1ty17 Offline
Loc: Georgia
technically yes they would, but to such a small degree that it is negligable. like the age old question of "does peeing in the ocean raise the sea level" yes, but to such a small degree that it doesnt matter.
i put an ounce or two of MMO in each tank of gas i get now.
#1972128 - 08/01/10 02:40 PM Re: MMO increases or decreases octane rating [Re: Lethal1ty17]
jsap Offline
Loc: NorCal
I see, so it would lower octane, but only to the degree of [censored] in the ocean. :)
Well, I'm trying to add up the various factors on possible contributors to pre-ignition. So far, I have these two factors:
1. MMO, by decreasing octane rating
2. carbon buildup, by increasing compression
On an old engine like mine (Mercedes M119.982) that was designed with 10:1 compression ratio and has 170K miles on it, I would think then to use a step colder heat range on the spark plugs?
(Reading the plugs would be nice, but I've been top engine cleaning, so the plugs are not readable right now.)
Beware of stealers
#1972192 - 08/01/10 04:00 PM Re: MMO increases or decreases octane rating [Re: jsap]
demarpaint Offline
Loc: NY
Incorrect timing can cause pre-ignition, so can carbon deposits on the valves, along with the wrong octane gas. Using MMO at the recommended dose isn't going to lower the octane. [censored] in the ocean pretty much sums up the effect on octane.
Have you tired very hot water via a vacuum line? That will get the carbon deposits out. Read up on it, it has been discussed several times on the site.
God Bless Our Troops
#1972226 - 08/01/10 04:51 PM Re: MMO increases or decreases octane rating [Re: demarpaint]
jsap Offline
Loc: NorCal
I've done water through pcv and brake booster, but the appearance of the piston is still the same. (Btw, I don't have any pre-ignition problems. I'm just looking for info for future reference.)
Regarding MMO, do you know the actual octane rating undiluted? Any quantitative info?
Edited by jsap (08/01/10 04:51 PM)
Beware of stealers
#1972848 - 08/02/10 09:25 AM Re: MMO increases or decreases octane rating [Re: jsap]
Jax_RX8 Offline
Loc: Northern VA, USA
This has been ask of Rich Kelly, Marvel Technical Director, and he has stated MMO is "Octane Neutral" in that it neither increases or decreases octane.
#1973720 - 08/02/10 11:00 PM Re: MMO increases or decreases octane rating [Re: Jax_RX8]
SAATR Offline
Loc: Here
In the proper concentrations, it would have no measurable effect much like most (if not all) octane boosters.
Time is an illusion, lunchtime doubly so
#1974328 - 08/03/10 01:14 PM Re: MMO increases or decreases octane rating [Re: SAATR]
Lethal1ty17 Offline
Loc: Georgia
run some seafoam to clean off those exhaust valves, or try some more water, ignition is caused by hot spots in the cylinder and carbon buildup is very good at this.
