Stuck ring?
by TurboFiat124
5 minutes 1 second ago
Protectant 303 vs. Wax on fiberglass surfaces
by mbacfp
Today at 03:17 PM
Jeep brakes
by buck91
Today at 03:10 PM
Any thoughts on the Hersheys attempted buyout?
by Vern_in_IL
Today at 02:55 PM
2009 Miata Race Car, M1 5w20
by 09_GXP
Today at 02:48 PM
FRAM TG3600 Cut Open
by HX520W
Today at 02:30 PM
Audi Q3 factory filter CUT OPEN
by car51
Today at 02:29 PM
MC FL910S CUT OPEN
by car51
Today at 02:04 PM
Any here storage your old License Plate
by MetalSlug
Today at 01:20 PM
Is the VCM on honda accord V6's a problem area?
by Tlhfirelion
Today at 01:09 PM
Biker gets instant revenge on car that cut him off
by John_Conrad
Today at 01:04 PM
Another W-10 saga
by Oldmoparguy1
Today at 01:02 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
93 registered (1BADDMAX, andyd, 01rangerxl, 87sammy, 09_GXP, 13 invisible), 1930 Guests and 10 Spiders online.
58322 Members
66 Forums
251046 Topics
#1949214 - 07/10/10 07:37 PM Help adding/changing floor jack oil
bob_ninja Offline
Loc: Ottawa, ON, Canada
I searched this site and other places, but cannot find any information on which hole to use to add or change oil in a floor jack. Here are the pics:
Floor jack images
It is around 7ish years old, never added or changed fluid. You can see the old oil is very dirty so it was due. I can see 2 ports:
1) the release valve screw
2) the screw which had the "Don't adjust" label
I didn't touch the release valve, so I was left to try the other one (2) which had the do not adjust cap.
I managed to drain the old oil, but adding new oil seemed to be very slow and difficult. More oil ended up overflowing and spilling out then went into the cylinder. Now it works except doesn't go very high, so probably needs more oil.
Can someone point out what opening is used to add oil????? What is the best method to add new oil?
thanks
#1949221 - 07/10/10 07:53 PM Re: Help adding/changing floor jack oil [Re: bob_ninja]
bkbenjy Offline
Loc: NYC
I have the same jack. A few weeks ago it stopped working. I filled it up with fluid and it works like new again.
There is a foam plug that you pull out.(circled in the picture)
Fill the oil in there and put the plug back in.
#1949223 - 07/10/10 07:55 PM Re: Help adding/changing floor jack oil [Re: bob_ninja]
Bill in Utah Offline
Loc: UT
I've NEVER changed the oil in any of my floor jacks. They work fine over the decades.
I don't think the fluid is that bad. Can't really tell the condition of the oil by looking at it anyway... (unless it turns to grease)
Looking at the photos, I'd say its the black on at a 45 degree angle right above the pumping piston.
Bill
#1949224 - 07/10/10 07:59 PM Re: Help adding/changing floor jack oil [Re: bob_ninja]
bkbenjy Offline
Loc: NYC
Bill
I would guess that it wasn't the condition of the oil that caused it to stop working. It was the lack of oil due to a leak.
That was the case with mine.
Edited by bkbenjy (07/10/10 07:59 PM)
#1949239 - 07/10/10 08:14 PM Re: Help adding/changing floor jack oil [Re: bkbenjy]
bob_ninja Offline
Wow, that is it :):):)
I am surprised it is just a foam/rubber plug. I expected something more solid, like a bolt.
Mine still worked. I was in my oil change mode and it was neglected and dirty, so decided to treat it with a new oil.
#1949243 - 07/10/10 08:18 PM Re: Help adding/changing floor jack oil [Re: Bill in Utah]
bob_ninja Offline
Thanks, got it.
Well I am used to seeing my motor oil turn black, change color. In this case I can see sediment settling at the bottom of the container, tiny specs of dirt everywhere. It is dirty.
Now I supposed it could have kept going for who knows how long. Still putting in new clean oil cannot hurt.
I now have a bigger more expensive model. I wanted to try changing oil on older/smaller one so that I don't ruin the new more expensive one when the time comes.
Thanks everyone :)
