Purolator PureONE PL14610 - 6k Miles
by ThirdeYe
07/23/16 07:47 AM
'06 Kia Sportage weird issue
by CincyDavid
07/23/16 07:33 AM
Dented Again
by AirgunSavant
07/23/16 06:42 AM
Does EGR blocking increase diesel consumption?
by berniedd
07/23/16 06:20 AM
Has BP left the gas retailing market?
by Vern_in_IL
07/23/16 05:45 AM
Commentary on Gate's Commentary on Electricity.
by Shannow
07/23/16 05:14 AM
techron article
by Joe1
07/23/16 05:08 AM
Lighter or heavier o-20 oils
by shDK
07/23/16 04:53 AM
Nice Gun Store Find
by bobbob
07/23/16 01:57 AM
Gun Prices
by bobbob
07/23/16 01:55 AM
Nissan Maxima pre-cats common problem
by Rohan
07/23/16 12:43 AM
License Plate Lights Quit
by Nick1994
07/23/16 12:39 AM
Omaid, Bwayne, krellmk, Annette, bimmergeek
58567 Registered Users
67 registered (Alex D, 4WD, 41 Plymouth, b1amgm47, Axe Man, acbent, 6 invisible), 1471 Guests and 8 Spiders online.
58567 Members
66 Forums
252136 Topics
#1941551 - 07/03/10 11:15 AM A/C Oil Charge R-134a What oil ??
crazyoildude Offline
Loc: New Jersey
on my 96 Plymouth voyager my compressor is making a little noise what oil should i use? I have pag 100 from a/c pro can i use that??
it says medium viscosity
I Am Certainly Not A Fan Of Any Oil Filter Using Those Restrictive Looking Tiny Louvers On Their Center Tubes.
#1941554 - 07/03/10 11:17 AM Re: A/C Oil Charge R-134a What oil ?? [Re: crazyoildude]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
Are you going to vacuum out the system of refrigerant first and then put the oil in or do you just want to charge your system with a bit more oil as is?
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1941557 - 07/03/10 11:19 AM Re: A/C Oil Charge R-134a What oil ?? [Re: crazyoildude]
bullwinkle Online   confused
Loc: Cincinnati, OH, USA
POE oil would probably be better-if you use the PAG oil be ABSOLUTELY SURE the system is leak-free & pull a vacuum with a vacuum pump at least overnight-moisture will turn the PAG oil to jelly & clog up your expansion valve!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#1941644 - 07/03/10 01:11 PM Re: A/C Oil Charge R-134a What oil ?? [Re: bullwinkle]
onion Offline
Loc: kansastan
I'm not exactly sure what you're trying to accomplish here. The ac compressor is noisy, so you just want to add oil? Is it leaking refrigerant somewhere?
AC systems are not like engines, in that you can't just say "hey guys- what oil do ya'll think I ought to use?". You can't just do an 'oil change' for your ac system.
A given ac system is designed to use a specific type and viscosity of oil. Unless your system has a leak or you've been changing parts, it likely still has the correct amount and type of oil in it- I'm not sure that adding oil is going to do anything for you. But if you DO feel the need to add some, you're going to need to do some research and see what kind of oil that system came with- I don't know. PAG 100 would be my guess- it's probably the most common. But you need to find out for sure. A factory service manual would be the best source of info. Auto parts store might be able to look it up for you. Automotive forums specific to your vehicle might be able to tell you- but take that with a grain of salt.
Whatever you do- DON'T just dump some POE oil in the system because 'bullwinkle' told you that that's the thing to do.
The invisible and the imaginary look exactly the same.
#1941780 - 07/03/10 04:34 PM Re: A/C Oil Charge R-134a What oil ?? [Re: onion]
Trav Offline
Loc: MA, Mittelfranken.de
My data is showing PAG 46. Have you lost refrigerant?
#1941831 - 07/03/10 05:59 PM Re: A/C Oil Charge R-134a What oil ?? [Re: Trav]
Chris142 Offline
Loc: apple valley, ca
That compressor can use 46 or 100 depending on what car it's in. It's basically a Sanden built for Dodge. But adding oil probly wont fix a noise.
If they put it in a car it gets 46 and a truck or van gets 100. I'd put the 100 you have in it since you have it already.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#1941878 - 07/03/10 07:02 PM Re: A/C Oil Charge R-134a What oil ?? [Re: Chris142]
Loc: New Jersey
its a 96 voyager
#1942022 - 07/03/10 09:30 PM Re: A/C Oil Charge R-134a What oil ?? [Re: crazyoildude]
nthach Offline
Loc: California
Sandens use PAG100, Denso uses PAG46.
#1942456 - 07/04/10 11:39 AM Re: A/C Oil Charge R-134a What oil ?? [Re: nthach]
Loc: New Jersey
How do i know which one is in the 96 voyager?
#1942482 - 07/04/10 12:19 PM Re: A/C Oil Charge R-134a What oil ?? [Re: crazyoildude]
mechtech2 Offline
Loc: Chicago Area
Maybe the compressor is making noise from too MUCH oil.
Most likely, if it did not leak out, it is OK in the oil department. That is if the pressure is enough to run the system, you almost assuredly have enough oil in there.
Noisy compressors are on their way out, or are overcharged.
And who knows what the history of this system is?
Edited by mechtech2 (07/04/10 12:20 PM)
#1942516 - 07/04/10 12:51 PM Re: A/C Oil Charge R-134a What oil ?? [Re: mechtech2]
onion Offline
Loc: kansastan
I don't know if you're willing to invest the time & money into a 14 year old vehicle... but if the noise is in fact coming from your compressor, it might be a good investment to go ahead and replace the thing before it has a catastrophic failure. 'Cause IF you run the thing to failure, it can scatter debris (metal & rubber chunks, mostly) through the condensor and plug up your expansion valve. If that happens, then you have a much bigger fix on your hands than just a compressor. And there can be reliability issues down the road if it isn't fixed right.
#1942998 - 07/05/10 03:06 AM Re: A/C Oil Charge R-134a What oil ?? [Re: crazyoildude]
nthach Offline
Loc: California
Look for a small silvery label on the compressor. If that is missing, a easy way to spot which is which is look at the hose connections. Denso compressors usually have their hoses mounted in the center, while Sanden usually has the inlet/outlet at the rear.
