I spun rod bearing #1 and damaged #2 badly during a HPDE @ Monticello Motor Club in NY. I drive a 91' 300ZX TT with the stock engine and turbos but with roughly 17lbs of boost on stock turbos, larger injectors, safe ecu tune, K&N style cone intake, cat-back, etc. however with stock intercoolers, radiator, and oil cooler. The car handles very well with coilovers and Sumitomo HTR ZIII 275 rear and 255 front tires.
The sump takes only a measily ~4quarts of oil to lubricate the 3L V6 TT. I usually run RL 5w30 however at this event I was running GC 0w30 and overfilled about .5quart with M1 15w50 EP.
I was driving pretty agressively, and keeping RPM's high up, shifting at 7k RPM. 10 minutes into my last session, I heard rod knock and pitted. No noise at idle, only above 2k rpm depending on the load. I was able to drive home the 100miles as well.
My initial thoughts were oil starvation, knowing that oil starvation issues are common with the Z32 when tracked at higher G loads, and most serious guys tracking this car have an accusump installed to prevent this. However I doubt myself sometimes considering I was only running sticky summer tires and not slicks.
Rod bearings 1-6 are shown from left to right respectively. A thing to note is that the rod bearings were damaged at the front of the engine. I need to find out which way oil is fed through the crank for lubrication, but I would have thought the front cylinders next to the pump would be first...
I have since replaced the rod bearings with new oem nissan bearings along with cleaning up the #1 journal to drive as long as I can until the I build up a replacement engine. Is this definitely oil starvation?
Pics:
Pics:
