Originally Posted By: BBuzecky
JAG: What the heck is an "Italian Tune-up"? Is that driving at high rpm's on the highway?
If that doesn't work you might have to try a "German Tune-up." It's only a bit more involved. Every time the car approaches the redline you have to scream out the word "SCHNELL." Some believe the process is furthered by adding a half pint of Dinkelacker to the crankcase and the remaining half pint to the driver.
Down my Mazda3 2.3l which has been running Synlube for 18k miles. Look at all that snake oil sludge.. (sarcasm). I can see further down than I can take a picture and it is clean down there. Less varnish color than i've seen in some pictures with "quality" dino and 3k oci's.
2002 Civic EX 80,000 miles
Maybe someone can explain what's with the tan color on the spring?
This car has seen almost every brand of dino, blend and syn oil. 3K-4K OCI the first 65K miles then I switch to 5K-6K OCI
I thought there was a more recent thread about oil fill hole photos but this one came up first in a search.
I finally replaced the grommet for my oil fill tube. This is for a full size Dodge van, so the tube is about 2 feet long.
Can't see much, except that even with precautionary wiping before removal, I got some debris inside.
The engine has about 30 k miles on it since The rebuild, I've been using M1 for the last ~8k miles, before that Valvoline conventional. This oil has ~600 miles on it.
