ACDelco X66P
by OldEuroCarLover
08/26/16 12:07 AM
FL910S C&P, 4,000 miles
by cb4017
08/26/16 12:02 AM
Mobil 1 Full Synthetic $3.99 AR Menards
by John_K
08/25/16 10:32 PM
Causes of steering wheel shudder
by buck91
08/25/16 10:14 PM
Brand new Focus ST...
by Striker
08/25/16 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
08/25/16 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
08/25/16 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
08/25/16 08:35 PM
Tundra steering wheel
by RN89
08/25/16 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
08/25/16 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
08/25/16 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
08/25/16 07:50 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
49 registered (Astro_Guy, Bear, Alex_V, 2015_PSD, beanoil, Al, 4 invisible), 914 Guests and 38 Spiders online.
58926 Members
66 Forums
253568 Topics
#1824342 - 03/20/10 11:26 AM Shelf Life of Brake Fluid - opened vs. closed
chefwong Offline
Loc: New York
In your opinion....what is the shelf life of brake fluid
- open in sealed tin can
- closed in plastic bottle
- open in plastic bottle
Just curious how long I can keep/use the latter in it's respective applications. I use ATE 200, Motul RBF600 and Castrol SRF. Cars using Motul and SRF get fluid chaned frequently. Street cars using ATE 2 years...1 year if I have time.
Just curious what is the longevity of shelf life in open or unopen applications..
#1824353 - 03/20/10 11:38 AM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: chefwong]
Deltona_Dave Offline
Loc: Deltona, FL USA
I would think that factory sealed, it should be good for a few years. Open and tightly closed in Florida humidity (where I live) would be about a year in plastic or metal containers. I write the date I opened it on the bottle. Brake Fluid is pretty inexpensive, so I dispose of it properly after roughly a year, since it will absorb humidity and moisture (I forget the tech term for it).
Emergency Vehicle Technician Law Enforcement
2013 Hyundai Sonata GLS 2.4
2013 Kia Optima EX 2.4
2012 Mazda3 2.0 SkyActiv
#1824367 - 03/20/10 11:48 AM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: Deltona_Dave]
Bluestream Offline
Loc: Waterloo, ON
In a tin can, a long time, maybe indefinate. In plastic 5 years according to Castrol. Open can; I would agree on a year or so. I'm not as anal about open containers as I used to be. Shop I used to go to had it kept in a one gallon tin can with a hole punched in the top of the can to allow the pump to pump out the fluid.
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#1824458 - 03/20/10 12:48 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: Bluestream]
widman Offline
Loc: Bolivia
Once it is opened, you have cut it seriously. use a little and close it tightly in a dry climate, fine. Every time you open it to look at it or take out a drop, you let humidity in.
Want to play?
In a humid climate, open a bottle and just leave the top off. it will overflow by the next day. That is water being absorbed that reduced the boiling point and makes it thicker.
I frequently see 5 or 6% in problem systems, but once it hits 25% the fluid is so thick it is hard to pump.
Richard's Car Restorations
#1824593 - 03/20/10 02:22 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: widman]
chefwong Offline
Loc: New York
Go figure....for those that are participating in this thread I'm going to assume you may follow similar brake flush schedules like I do....
I take brakes and tires very seriously...
And then there is the majority which I had to guess probably not have flushed their system in 6 years...
#1826844 - 03/22/10 12:02 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: chefwong]
dailydriver Offline
Loc: Bucks County, Pa.
...or my brother, who has not flushed, nor changed his in 11 YEARS!!! (In his daily driver/beater) crzy
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#1826847 - 03/22/10 12:06 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: Deltona_Dave]
dailydriver Offline
I believe hygroscopic is the term you are looking for.
And the italicized part of your post indicates that you most definitely are NOT a Castrol SRF user!!
M1-206 oil filter
#1827585 - 03/22/10 10:32 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: dailydriver]
crinkles Offline
Loc: Australia
just throw away unused portions. always use from fresh bottle.
2002 Toyota Camry 2.4L
2005 Toyota Camry 2.4L
#1827606 - 03/22/10 11:00 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: crinkles]
sciphi Offline
Loc: Upstate NY
I have a lot of unused fluid after replacing all the hard lines on my car. That fluid wasn't touched for 10 years. It was nasty.
Good to know the fluid I buy on the shelf is still in okay shape.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#1827778 - 03/23/10 07:08 AM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: sciphi]
KrisZ Offline
Loc: Toronto, Canada
Tht's why I don;t keep any brake fluid around, I never need it except when I flush the system. It usually takes a little over 0.5 quarts to flush the system completely, and I toss recycle what's left over.
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#1828337 - 03/23/10 03:27 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: KrisZ]
eljefino Offline
Loc: ME
The stuff in your car's plastic reservoir is good for two years so IMO an opened container with the lid on is good for at least that long.
Since it turns brown/black as it ages, compare the bottle to the reservoir. If it's more clear, you're improving things by adding it. (Though any off tint would have me chuck it.)
#1833362 - 03/27/10 07:30 AM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: eljefino]
widman Offline
Loc: Bolivia
two years in the car as long as you look at it through the plastic, not taking off the top to "see better". But in the car the air you close in is a few ml.
In the bottle, if it is half full, you are locking in 6 ounces of moist air that will be absorbed. if you then open and take out an ounce, you are locking in another 7 ounces of moist air.
As one guy once told me: "This is a great product. Each week I top off my brake fluid and the bottle never empties."
#1847741 - 04/06/10 08:31 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: widman]
PandaBear Offline
Loc: Silicon Valley
They should start selling them in plastic pouches instead of bottle, so no air can get in.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#1847752 - 04/06/10 08:39 PM Re: Shelf Life of Brake Fluid - opened vs. closed [Re: PandaBear]
cjcride Offline
Loc: Ontario Canada
^+10
