quote:
c. Titan GT1 0W20 performance level is very much higher: Lower oil's friction drag, higher shear and temperature stability, very high lubricity, the viscosity is lighter/thinner therefore better flow-rate and cooling rates due to higher oil circulation within the engine. Refer to the attached folder or technical specification about the Titan GT1 0W20.
Question no.3: Titan GT1 0W20 seems to be very thin oil, can be used in Singapore climate?.
a. Titan GT1 0W20 can be use in and under Singapore's climate with no problem, it depend a lot on the conditions of the car or vehicle. Titan GT1 0W20 is recommended for newer and mechanically sound cars only. It is not recommended for cars that consume oil or the internal engine's components are worn out.
b. If you are using Titan GT1 0W20 the emphasis is also on the vehicle operating temperature and control. The higher the operating temperature, the higher the oil consumption. Vehicle with poor or worn oil pump and cooling system are not recommended to use Titan GT1 0W20.
c. If you are not sure (kaisu) about using Titan GT1 0W20, initially mix 50% of Titan GT1 0W20 with 50% of Silkolene Pro-S or GT1 Turbolene, SuperSyn 5W40 or 5W50 or Unic MC-Plus.
d. Titan GT1 0W20 have being tested on the Sepang race track for the 12 hours endurance race with not power loss, overheating, oil loss, and below the factory's recommended wear and tear on the engine's components.
