1999 ford expedition factory mercon v synthetic??
by merconvvv
07/23/16 11:40 PM
Buick 3800 - "Von Voyage" oil change?
by Alex_V
07/23/16 10:41 PM
Low oil level light on, but level not THAT low....
by gregk24
07/23/16 10:26 PM
Is SuperLube syn multi grease universal
by NattyBoh
07/23/16 10:05 PM
How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
2016 Tacoma 3.5L V6 4x4
by NavyVet88
07/23/16 07:10 PM
Question on 05 Nissan tranny w/120k
by NattyBoh
07/23/16 06:58 PM
Denso FTF oil filters
by mclasser
07/23/16 06:50 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
59 registered (ag_ghost, 4WD, 69GTX, 41 Plymouth, aquariuscsm, 6 invisible), 1259 Guests and 15 Spiders online.
58578 Members
66 Forums
252173 Topics
#1674404 - 11/17/09 01:34 AM 99% Isopropyl alcohol as fuel additive?
SecondMonkey Offline
Loc: OR
I happen to have 10 spare gallons of 99% anhydrous isopropyl alcohol with no particular use. I'm wondering if I should use this as a fuel additive? I know that's all that "Heet" fuel dryer is made out of. Would it be really bad to add more alcohol on top of the 10% ethanol we already get? Could I use as an octane booster? The jeep has been pinging a little on 87 lately...
I remember once I was trying to start my lawnmower on old/wet fuel. It wasn't gonna happen. So I dumped a bottle of 91% rubbing alcohol into the gas tank to soak up the water, but, the engine actually ran great on the mix...probably about 50/50. It just so happens I was going to take the head off and replace the gasket anyway, and when I did, it was REALLY OBVIOUS that the big dose of alcohol had knocked off a lot of built up carbon. I wonder what the max safe ratio would be? Does this stuff eat rubber like ethanol and methanol?
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe." - Albert Einstein
#1674538 - 11/17/09 07:33 AM Re: 99% Isopropyl alcohol as fuel additive? [Re: SecondMonkey]
doitmyself Offline
Loc: MI
According to this site, it is not a good idea, but what do I know (not much)?
http://www.fueltestkit.com/is_gas_additive_safe_with_e10_list.html
Edited by doitmyself (11/17/09 07:41 AM)
Edit Reason: Update link
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#1674540 - 11/17/09 07:36 AM Re: 99% Isopropyl alcohol as fuel additive? [Re: SecondMonkey]
mechtech2 Offline
Loc: Chicago Area
What does that 1% consist of?
Isopropyl is not as horrible as methanol for corrosion and problems.
It has high octane, but you'd have to mix a lot to get meaningful increases.
Since the gas probably already has 10% alcohol in it, why not play it safe and add enough of your own to go up to 15% total [add it at a 5% extra rate]?
This is safe and will make good use of it.
#1674572 - 11/17/09 08:12 AM Re: 99% Isopropyl alcohol as fuel additive? [Re: mechtech2]
dwcopple Offline
Loc: Michigan
[censored] yes. Pour it in.
2015 Chevrolet Silverado All-Star edition 4.3 Ecotec3 V6
2011 Chrysler 200 Limited 3.6L V6
#1675394 - 11/17/09 07:28 PM Re: 99% Isopropyl alcohol as fuel additive? [Re: mechtech2]
Loc: OR
Most likely water. This is pretty pure grade lab stuff. Somebody paid a lot of money for it! LOL
Does anybody know the pure octane rating of isopropyl? Tried google but couldn't find anything...
#1675636 - 11/17/09 10:25 PM Re: 99% Isopropyl alcohol as fuel additive? [Re: SecondMonkey]
Loobed Offline
Loc: Northern California, USA
There may be some "smell-bad(R)" or "taste-bad(R)" in that 1%.
An alcohol drag engine usually has between 20 to 1 and 22 to 1 compression.
There are different types of alcohol and they are not all the same. Some are more soluble in water and others are more soluble in oil. I think it depends on the amount of carbon atoms and where the OH is attached.
Edited by Loobed (11/17/09 10:26 PM)
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#1675926 - 11/18/09 07:18 AM Re: 99% Isopropyl alcohol as fuel additive? [Re: Loobed]
mechtech2 Offline
Loc: Chicago Area
A lot of my saved info is lost due to computer problems.
But figure about 105 octane for the isopropyl.
Any water will be held in suspension and be harmless.
We use corrosive methanol in the wheelstander.
Low compression with high valve overlap, but a lot of blower overdrive!
#1675950 - 11/18/09 07:41 AM Re: 99% Isopropyl alcohol as fuel additive? [Re: mechtech2]
n8wvi Offline
Loc: 42.4N 85.7W
Could the cleaning have been from the water? If it was a 50/50 mix of gasoline and isopropyl, and the isopropyl was 91% alcohol and 9% water, you were running 4.5% water in your mix.
On a side not, while water may not TECHNICALLY raise octane, I think it reduces the need.
'10 Legacy GT EJ255 24k miles
'12 Impreza CVT (38MPG!)
#1676748 - 11/18/09 07:23 PM Re: 99% Isopropyl alcohol as fuel additive? [Re: n8wvi]
Loc: OR
I don't know, I was thinking about that. It sure was amazing to see though, I wish I would have taken pics. Maybe this spring I'll try it again under more controled conditions to see what happens. :) The extra high temp of the lawnmower engine might have something to do with it too, vs under 200 for a car engine.
