Help with iphone on the home network
by buck91
05/06/16 06:45 AM
2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
83 registered (askani79705, AirgunSavant, aquariuscsm, 97f150, Asterix, 2015_PSD, 10 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248539 Topics
#1634461 - 10/16/09 09:08 PM How short to cut grass for last cut before snow.
rmattingley Offline
Loc: La Crosse, Wi
I cut mine 3 inches all summer, now its is time to get ready for the snow. Do I cut it shorter, or leave it at 3 inches. Thanks
#1634486 - 10/16/09 09:22 PM Re: How short to cut grass for last cut before snow. [Re: rmattingley]
Barkleymut Offline
Loc: Richmond, VA
There is never a good time to cut fescue or bluegrass under 2 1/2 inches. This shocks the grass and the cold weather also shocks the grass. Put down a good winterizing fertilizer and wait till spring to worry about the lawn again.
If it makes you feel any better I owned a landscaping company for 8 years.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#1634493 - 10/16/09 09:26 PM Re: How short to cut grass for last cut before snow. [Re: rmattingley]
af0h Offline
Loc: Park Hills, Missouri
Can't say i've ever done anything special.
I just cut it like normal and trim very well - so it all looks good. But then, I never cut it real short anyway...
hornets
af0h - Rob
af0h - Rob
MMO user for 26-years.
#1634552 - 10/16/09 10:02 PM Re: How short to cut grass for last cut before snow. [Re: rmattingley]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Final cut. Normal length.
The only area I may cut short is the dog poop areas and the grass in that direction. Pooches don't like walking through long wet grass. What can I say?
#1634553 - 10/16/09 10:02 PM Re: How short to cut grass for last cut before snow. [Re: af0h]
Nick R Offline
Loc: Albany, NY
I usually cut it on the 3rd setting, but before winter I set it down to the 2nd notch. It helps to pick up mulched up leaves, acorns, and pick up some of the junk. Doesn't quite de-thatch it, but it's the next best thing.
2013 Ford Focus SE 2.0L/70,000miles/Motorcraft Blend 5W-20/FL-910S
#1634790 - 10/17/09 04:15 AM Re: How short to cut grass for last cut before sno [Re: rmattingley]
Johnny Offline
Loc: Retired | Wausau, WI
We probably have about the same kind of grass considering where we live. I set my mower on 3" and leave it there all year. I fertilize four times per year and will be putting down the final winter fertilizer next week. I will mow the grass for the last time just before I fertilize and mulch any leaves that are on the lawn at the time.
#1634893 - 10/17/09 08:48 AM Re: How short to cut grass for last cut before sno [Re: Johnny]
SubLGT Offline
Loc: Idaho
I cut mine shorter than usual, but I don't scalp the lawn like some of my neighbors. If you leave it long, the grass will mat under the snow, which can't be beneficial.
#1635135 - 10/17/09 01:28 PM Re: How short to cut grass for last cut before sno [Re: SubLGT]
TurboLuver Offline
Loc: SW Ohio
Same length I cut it all year 3".
#1635250 - 10/17/09 03:12 PM Re: How short to cut grass for last cut before sno [Re: TurboLuver]
el_zorro Offline
Loc: Michigan
I also keep mine at 3 inches all through the season. I used let it grow longer in the fall before the snow fell but one year when we got a lot of snow cover, the mice burrowed under the snow, ate the longer grass and made nests under the snow with the grass. Made a lot of mess. Since then I have cut it the normal length in the fall.
#1637486 - 10/19/09 11:22 AM Re: How short to cut grass for last cut before sno [Re: el_zorro]
RWEST Offline
Loc: Somerset County, PA
According to my lawncare guy, you should cut the grass shorter each time, ending up at 1.5" (it's been a pretty dry summer, so we'd been keeping it between 2.5 - 3") for the final mow, to avoid snowmold issues. This is for common northern rye/bluegrass lawns.
"even if you're paranoid, they can still be following you" hide
"live so the preacher doesn't have to lie at your funeral" wink
