Validity of the "4-ball" wear test in engine lubes
Canyon City Oregon
I keep running across Amsoil related threads, and every so often the old "4-ball test results" Amsoil uses in their advertising resurfaces. I've been curious as to the validity of that test method, in regards to *engine* oils, and did an Internet search - found out others, including Mobil co. had related comments and opinions:
Quote:
Question:
Oil Film Strength of Mobil 1 Compared with Royal Purple
Does Mobil 1 have less oil film strength than Royal Purple? I have seen many times the friction test of oils using the machine that test the oil film, test result shows that Royal Purple has more friction protection that Mobil 1 does, seeing these results makes me think that Mobil 1 is lacking some benefits, therefore Royal Purple has the better protection of all.
-- Guillermo Tristani, Miami, OR
Answer:
There are certain oils in the market today that use EP (extreme pressure) additives in their engine oil that are really designed for gear oils and not engine oils. Extreme pressure additives are typically not used in engine oils for a number of reasons but the most important is because they can cause engine corrosion over time. The rigs being used in these demonstrations are primarily designed for industrial applications like gear oils where extreme pressure is an important performance feature you need. These demonstration rigs have very little to do with modern engines and that is the reason that market leading oils in the industry perform poorly in these tests
I guess a more direct approach/question where the "4-ball" test is concerned - especially since Mobil stated that particular test was primarily for gear lubes and similar where characteristics differ significantly from that of purely ENGINE lubes - is, do ANY major oil refiners use that particular test to evaluate and advertise their engine oils? (*I* sure haven't seen any!) OR, is it as Mobil claims, primarily for test and evaluation of gear lubes and similar where different operating characteristics and lube requirements exist?
If it IS primarily for gear lubes - and use pretty much restricted to those type tests by most lube producers, WHY does Amsoil - and apparently Royal Purple use that test on their *engine oils* - and then rely upon the results as a major advertising tool?
Should buyers be looking for, and satisfied with an engine lube largely because it provides substantial gear lube characteristics? Not a trick question, there ARE gear trains in many engine types - as well as various direct sliding metal-to-metal contacts - such as in the camshaft/valvetrain - just not sure I'd necessarily be satisfied with an engine lube that placed greater emphasis upon the gear-type characteristics, than what the rest of the engine required - as the Amsoil focus upon gear train test methods and advertising might imply...
Are there no BETTER and more pertinent oil industry tests available SPECIFICALLY designed and accepted specifically for engine lubes? IF so, where can THOSE test results by major dino and synthetic producers be seen?
How about it - is the "4-ball test" really a valid test of *engine* lube quality and performance - or just a smoke-and-mirrors advertising gimmick used by Amsoil that is rather meaningless outside gear lube testing?
This has been addressed a billion times. Noria had a good write up about it and essentially it's used as a screening test for additives. Has poor correlation to real world engine testing.
Oils have to go through sophisticated, controlled engine sequence testing to prove their wear capabilities.
Quote:
"The 4-ball test (ASTM D4172) is often used as a screening test for many different lubricant types that contain antiwear additives or similar base oil properties. Other tribo-mechanical bench tests are often used as well, including the Timken Test (ASTM D2782) and the Pin and V-Block (ASTM D2670). Because engines have different contact geometry, loads, metallurgy and speeds, numerous bench tests and test protocols are needed. It is not uncommon for several oils to be tested using two such methods and to find that the performance rankings between the oils to reverse (no correlation). This is why, among other reasons, Passenger Car Motor Oils and Heavy Duty Oils (diesel crankcase) are tested in actual engines using controlled methods such as ASTM D5533 Sequence IIIE and D5302 Sequence VE.
Jim Fitch, Noria Corporation"
Its a pretty useless test for engine oils.
It is a pretty useful test for greases and gear lubes.
This is why no major oil manufacturer uses it to test their oils. But they do use it (ASTM D-4172) to test their greases and gear oils.
It is a wow-factor test. It doesn't mean the companies who use it are selling a sub-par product and using smoke and mirrors, but the results are really not all that relevant to what takes place inside an internal combustion engine.
Another example is the "one armed bandit" machines that Shaeffers salesmen have used. Doesn't mean the oil is a bad product, but the performance of EP additives in an EP test has little to no relevance to the product's subsequent performance in a gasoline engine.
If you look at Mobil's PDS for gear lubes and some other lubes, they use the 4-ball wear test. It is a legitimate test, but not called for in motor oil testing.
I would hardly call RLI a major oil manufacturer (compared to SOPUS, EM, BP...etc).
Per the sheet you posted, RLI used:
1. DIN 51354 FZG (Gear oil test)
2. ASTM D-4172 (four ball)
3. Denison/Vickers pump wear tests
4. Penn State Micro-oxidation test
5. ASTM D 2272 (Standard Test Method for Oxidation Stability of Steam Turbine Oils by Rotating Pressure Vessel)
6. ASTM D-5864 (Standard Test Method for Determining Aerobic Aquatic Biodegradation of Lubricants or Their Components)
7. ASTM D4684 (MRV) (Standard Test Method for Determination of Yield Stress and Apparent Viscosity of Engine Oils at Low Temperature)
8. ASTM D-97 (Pour Point)
9. NOACK (Volatility)
10. ASTM D-892 (Standard Test Method for Foaming Characteristics of Lubricating Oils)
11. ASTM D-6082 (Standard Test Method for High Temperature Foaming Characteristics of Lubricating Oils)
To test their lubricants.
Originally Posted By: RLI
A modified Four-Ball Wear Test using a sequential method to obtain a "run-in" wear and a
"steady-state" rate of wear has also been developed for use with heavy-duty hydraulic
systems using a large Caterpillar data base. (6) (7) In many cases, such as transmission fluids
for heavy loaded gearboxes, the lubricants are required to have superior extreme pressure
(EP) properties. The properties can be screened using the Four Ball Wear Tester assembly.
This test can be supplemented with a scuffing evaluation of lubricants by increasing the
load until scuffing occurs.
Now, for comparison, lets look at the tests (the posted ones) that a single grade, in this case M1 0w40, has been tested with:
1. API SM/SL/SJ/CF
2. ACEA A3/B3
3. ACEA A3/B4
4. NISSAN GT-R (manufacturer specific)
5. MB-Approval 229.3
6. MB-Approval 229.5
7. GM-LL-A-025
8. GM-LL-B-025
9. BMW LONGLIFE OIL 01
10. VW 502 00
11. VW 505 00
12. PORSCHE A40
13. ASTM D 445 (Standard viscosity test)
14. ASTM D 874 (Sulfated Ash wt)
15. ASTM D 92 (Flash point)
16. ASTM D 4052 (Density)
17. ASTM D 4683 (HTHS)
18. ASTM D 4684 (MRV)
Not to mention the tests that the add packs and base oils would have gone through that are not mentioned on the oil's spec sheet.
My view of ASTM D 4172 has become more positive lately. It's not a be-all/end-all, but it's not too shabby, either.
See below, from Southwest Research Institute (renowned for excellent applied research):
http://www.swri.org/4org/d08/ShearTst/4ball.pdf
And SAE uses it to test engine oils:
http://www.sae.org/technical/papers/930160
And the Army included it when evaluating scuffing test correlations. Table 3 on page 13 is interesting:
http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA321790&Location=U2&doc=GetTRDoc.pdf
Best
K
Looks like syn. and ester-based oil has some superiority in the ring/piston area of high speed heavy duty diesel engines.... some board members may be surprised now.
Oh wait, I forgot it's all about the add-pack.
QUOTE: "The rigs being used in these demonstrations are primarily designed for industrial applications like gear oils where extreme pressure is an important performance feature you need. These demonstration rigs have very little to do with modern engines and that is the reason that market leading oils in the industry perform poorly in these tests"
Sounds similar to what Royal Purple said about the 4-ball test this month. (That it's invalid to compare engine oil brands.) Next thing Amsoil will do is add teflon to their oil
Yet Royal Purple has used the "one armed bandit" in the past, which is equally useless.....
"motorkote" also uses the one armed bandit.
what they dont tell you is pert plus shampoo
outperforms all the oils there....
at least until it heats up.
QSounds similar to what Royal Purple said about the 4-ball test this month. (That it's invalid to compare engine oil brands.)
So in other words we should just avoid all the MLM and other shady companies. We can't trust a single word out of their mouths.
LOL, well, I don't recall XOM, SOPUS, Ashland or BP ever using one of these tactics to sell their product
Big oil is far from innocent in marketing. Aside from that, we do have to remember that the boutique oils had to differentiate themselves somehow from the mainstream companies, particularly when trying to explain why they didn't have the latest certifications.
I would tend to agree here. Engine oil does so much more than just lubricate under pressure. It has to clean and suspend soot and combustion by-products(carbon etc),dissipate heat since engine oil cools more of the engine than the coolant does,it also has to negate the sulfur that inevitably gets by the rings and absorbed by the oil during the combustion process and once,moisture in the form of condensation is present it can turn into sulfur if acid.
So I think the 4 ball test can show how well an oil performs under pressure however it doesn't represent all the other functions an oil has to do in an engine.
As a marketing tool it's great and likely helps sell oil but the test doesn't address any of an oils other,very important functions
I recently read an article which suggests that EP products can be beneficial to engines as the rocker arms and some other components see high pressures.
I've never seen rockers wear out, even in high mileage and poorly maintained engines
This isn't a challenge, just adding my differing experience to the mix.
I've seen plenty of worn out rockers.. even on well maintained engines. It was pretty customary to wear out the rocker bushings in 60-80K miles on a four cylinder Land Rover engines, for example. I was a LR dealer tech in the '80s and '90s and worked on them back into the '70s. In about 210,000 miles of driving my own Series IIA, I replaced rocker bushings twice. I was a 3K/3mo guy then, pretty anal about maintenance and (though I was pretty uneducated o oils then) most often used 20W50 Castrol or 10W40 Chevron Supreme. My general LR comments would hold true thru the '90s anyway, when my pretty vast experience with them was placed into suspended animation.
Along the same lines, I saw many bushed rocker arms that were worn out in my wrenching career that goes back to the late '60s. Hard to define the cause and effect since I wasn't really looking for any. Most times I was overhauling the engines at the time. Have seen many fewer problems with the stamped rocker with the ball pivots, but even then worn out rockers are not unusual.
Whether this experience means anything in light of today's better oils, I don't know.
On my Volkswagen PD-TDI the rockers do not wear out, but instead the cam wears out. The high pressure lifters exert too much pressure and leaves scoring, so I can see how a strong oil would be beneficial.
