Does Anyone Remember...
by pscholte
08/30/16 10:21 PM
Oil filter for fuel filter?
by leroyd92
08/30/16 10:19 PM
YouTube search geniuses help me out!
by Vern_in_IL
08/30/16 10:00 PM
BMW i8 Could Have 750 HP All-Electric After 2020
by HTSS_TR
08/30/16 09:48 PM
1991 Audi 200 Turbo Automatic Oil Standard?
by Logos
08/30/16 09:43 PM
Chevron & Sunoco & Speedway $100 Gift card $92
by gojoneeded
08/30/16 08:41 PM
Santa's Not Going To Be Happy
by Warstud
08/30/16 08:29 PM
can someone explain the Ecoboost to me?
by columnshift
08/30/16 07:50 PM
4 dragging weak brakes (after parked for a year)
by columnshift
08/30/16 07:34 PM
New S&W Shield 9
by funflyer
08/30/16 06:42 PM
ecoboost 3.5
by boostnation
08/30/16 06:30 PM
Meijer, Mobil and the joys of Labor Day stackation
by fdcg27
08/30/16 06:25 PM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
18 registered (AnthemBassMan, Atesz792, fonecord2, c502cid, 5 invisible), 639 Guests and 8 Spiders online.
58964 Members
66 Forums
253791 Topics
#1545429 - 07/26/09 11:21 PM Rear diff fluid for 08 Silverado - Mobil1?
Mossyoakglock Offline
Loc: Nashville, TN, United States
I need to change the rear diff fluid on an 08 Silverado and 07 Avalanche, both with the G80, so it's not a limited slip. The GM spec for the fluid is 9986115. But, after looking on the back of all the different gear oils, none of them say they meet this specification. On the GM forums, a lot of people are using RP or M1 75w-90. All of them say they exceed GL-5 specs. Is it ok to run the M1 in my truck without any issues? From what I've read, it seems like it should be ok. What are your thoughts?
Also, I thought I read somewhere that Mobil1 makes the GM gear oil. Is this true?
#1545439 - 07/26/09 11:40 PM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: Mossyoakglock]
Jason2007 Offline
Loc: virginia
I ran RP 75w-90 in my 06 Silverado w/G80 and it worked great.
#1545446 - 07/26/09 11:46 PM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: Jason2007]
killagt Offline
Loc: MS
Why do u want to change it so early ? I think GM already use good stuff on it and it should last a very very long time. Mobil product is what GM factory fill.
#1545460 - 07/27/09 12:02 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: killagt]
The Avalanche has 70K on it and my truck has 23K. I want to get any metal shavings out of it from break-in, plus it's cheap insurance.
#1545468 - 07/27/09 12:26 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: Mossyoakglock]
killagt Offline
Loc: MS
Are you still under warranty ? anyway Mobil 1 sound great. Or AMSoil is also exelence, btw what ever syntetic gear oil that say already had the Additive, just add another bottle of GM Additive to it.
#1545486 - 07/27/09 01:01 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: Mossyoakglock]
AzFireGuy79 Offline
Loc: Arizona
It meets GL-5. You are golden. Mobil 1 makes a very high quality gear oil.
2008 Chevrolet 2500HD 6.6 DMAX, CCSB,Z71
2011 JEEP Grand Cherokee Overland HEMI 5.7
#1545521 - 07/27/09 03:18 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: AzFireGuy79]
Turk Offline
Loc: MN
If the truck is a 4x4, change the front diff. & the transfer case - that is where I found most of the shavings.
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#1545541 - 07/27/09 05:24 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: killagt]
Rob_Roy Offline
Loc: Northern, NY
The idea is to remove the factory fluid and all of the break-in metal it contains.
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
#1545549 - 07/27/09 06:15 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: Rob_Roy]
Boomer Offline
Loc: Pennsylvania
Ran Mobil 1 75W-90 in my 97 Chevy fullsize 5.7 liter 4WD and never had an issue in 110,000 miles/10 years!
2013 VW Passat TDI SE, 33,300 miles
2014 VW Jetta TDI SportWagen 18,055 miles
#1545554 - 07/27/09 06:35 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: Boomer]
JHZR2 Offline
Loc: New Jersey
M1 or Amsoil SVG.
I like the SVG as you can get a 75w-110 and have a bit heavier oil without much sacrifice.
#1545577 - 07/27/09 07:38 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: JHZR2]
NHHEMI Offline
Loc: NH
That part # is for the GM 75W-90 synthetic Grape Juice. Another overpriced GM OE fluid. I am sure the Mobil 1 would be ok.
I had a 2005 Silverado with the G80 and a 2007 Silverado( NBS - same as your 08 )with the G80 and ran RP 75W-90 front and back. Worked great.
Proud user of Royal Purple products thumbsup
#1545735 - 07/27/09 10:40 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: NHHEMI]
dnewton3 Offline
Loc: Indianapolis, IN
I did some research on this GM "grape juice" a couple year ago.
Here's a synopsis of what I can share. Make sure to note the there are "spec" numbers, and there are "part" numbers. The spec is for the fluid; the part is for the packaging.
GM #9986115 is a spec for the blended product of GL-5 hypoid gear oil (of synthetic base stock) and some friction modifier.
Why FM in a "locker" rear end? Because there is a small actuating clutch that moves the locking pawl mechanism, and that clutch can "chatter" at times. The FM quiets the operation of that clutch. It will not be hurt if you don't use FM, but it can be anoying both with audible and physical nuisance locking.
GM apparently buys the hypoid oil in bulk, and the FM in bulk, and mixes them at the plant? (Best info I could find at the time). So, to make the "grape juice" availabe over the counter, they had to create a new spec (9986115) for the "blend" of oil/FM, and then make it available in a bottle for sales over the parts counter. (there were, at the time, both pint and quart bottles, so the part numbers you may see quoted will vary, depending upon container size).
The reality is that the "grape juice" diff fluid from GM is nothing special; it's a "synthetic" GL-5 with FM. That's all. It performs reasonably well, unless you consider that it's stupid-expensive compared to its competitors such as Mobil 1.
Here is a link to a conversation regarding some information straight from some tech guy at Eaton, the manufacturer of the G-80 locking units. In a nutshell, they used "Texaco" brand fluids for testing, but he clearly states that multiple grades and base stocks can be used, as long as they meet GL-5. Read where he calls out both dino and synthetic options for the GM fluids.
If you'll peruse down about 1/2 way, you'll see a topic for "automatic locking differential lubricants"
Here's the link: http://www.swedishbricks.net/700900FAQ/Driveline1.html
Amsoil also has similar info in their TSB #DT-2004-07-01.
Hope that clears it up. Use any GL-5 you want; you'll be fine. Use "synthetic" if you want longer fluid intervals.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#1545770 - 07/27/09 11:24 AM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: dnewton3]
Ken2 Offline
Loc: Washington St.
Don't think that GL-5 is anything special. That spec has been around almost forever. It means that the gear oil handles the sliding motion of hypoid gear teeth. Hypoid means that the input and output are in different planes. Notice how the height of the input is lower than the output--that's hypoid, and that requires GL-5.
It appears that differential makers are specifying synthetic gear oil in certain modern differentials because the oil handles higher loads and temperatures before the oil breaks down (and when the oil breaks down the parts fail very soon thereafter). The differentials are being made smaller, lighter, and cheaper, and relying on more robust gear oil for their survival.
During the warranty period, I'd strongly suggest that you stick with GM's distinctive gear oil. If you have a warranty claim, you don't want anything to show that you used an non-approved product. (And, no, I do not consider Amsoil's warranty equal to any equipment manufacturer's warranty...read all of Amsoil's fine print about how to qualify for reimbursement.)
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#1546028 - 07/27/09 03:05 PM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: AzFireGuy79]
SubLGT Offline
Loc: Idaho
 Originally Posted By: AzFireGuy79
...............Mobil 1 makes a very high quality gear oil.
If this is true, why did M1 shear out of grade after only 10,000 miles in my Subaru?
#1546254 - 07/27/09 07:36 PM Re: Rear diff fluid for 08 Silverado - Mobil1? [Re: JHZR2]
tig1 Offline
Loc: Illinois
I use it in my Merc with no problems, and my sons Ranger has it in his diff. also no problems. 333,000 miles on two diff oil changes.
2007 Ford Fusion 187,000 miles
M1 0-20 AFE
2007 Ford Focus 158,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
