There are other filters in the 22Mx1.5 thread ..but..YMMV
X'ref these to
WIX
P502048
LUBE SPIN-ON FULL FLOW
A - OD (Inches) 3.54
B - Thread Size (Inches) M22 X 1.5
C - Length (Inches) 3.18
D - Gasket OD (Inches) 2.52
E - Gasket ID (Inches) 2.27
Product Type Description LUBE SPIN-ON FULL FLOW
Primary Application HONDA 15400-PA6-305
Product Group FL
P502072
A - OD (Inches) 3.64
C - Length (Inches) 5.47
D - Gasket OD (Inches) 2.75
Primary Application MOTORCRAFT
Product Group FL
P550166
LUBE SPIN-ON
A - OD (Inches) 3.67
C - Length (Inches) 5.42
D - Gasket OD (Inches) 2.83
E - Gasket ID (Inches) 2.46
Relief Valve Setting (PSI) 17-22
Primary Application ONAN 122-0550
Product Group F
P550357
LUBE SPIN ELMNT
A - OD (Inches) 3.78
C - Length (Inches) 3.78
Relief Valve Setting (PSI) 10-15
Anti Drain Valve (Y/N) Yes
Primary Application FORD 844F6716AA
Product Group F
P550389
LUBE FILTER SPIN-ON
A - OD (Inches) 3.15
C - Length (Inches) 3.94
D - Gasket OD (Inches) 2.48
E - Gasket ID (Inches) 1.99
Relief Valve Setting (PSI) 8-11
Primary Application ISUZU 8941145840
Product Group F
P550600
LUBE SPIN-ON
C - Length (Inches) 3.17
D - Gasket OD (Inches) 2.94
E - Gasket ID (Inches) 2.43
Primary Application HONDA 15400PL2004, 005, 305
Product Group F
P550794
LUBE SPIN ON
A - OD (Inches) 3.00
B - Thread Size (Inches) M22 x 1.5
C - Length (Inches) 3.26
Relief Valve Setting (PSI) 20
Product Type Description LUBE SPIN ON
Primary Application GM 2007 LIGHT TRUCK
Product Group FL
P550965
SPIN ON LUBE
C - Length (Inches) 3.58
D - Gasket OD (Inches) 2.81
E - Gasket ID (Inches) 2.42
Relief Valve Setting (PSI) 15
Primary Application FORD LIGHT TRUCK
Product Group F
P553315
ELEMENT, LUBE SPIN-ON
A - OD (Inches) 3.82
C - Length (Inches) 5.51
Primary Application FORD 785F-6714-AA3A
Product Group F
