OK always the same topic on MoS2 but I've never been able to come to a nice conclusion so I'd like to narrow it down a bit further.
There is a huge controverse on the benefits/drawbacks of MoS2 additive in a manual transmission (synchronized). I don't want to go into the topic of performance of synchronization with antifriction additives as this had been debated already. Here I'd only like to get evidence of potential corrosivity problems of MoS2 on brass (mainly used in synchronizer rings in manual gearboxes). So my questions are:
- is this true that over time MoS2 will degrade into sulphuric acid if supplemented in a gearoil?
- Is it true that MoS2 is especially corrosive for brass synchros?
- If the above is true, then does it mean that the use of any MoS2 (additive or not) is not acceptable in a manual gearbox using brass synchros? If not, what would make the use of MoS2 acceptable?
I'm especially targeting this debate around Lubro Moly MoS2 Gearoil treatment additive (20g tube) that is supposed to reduce wear of the box. I'm using it right now, have worked great over the last 50'000km but this doesn't mean there is no corrosion occuring....
Thanks for your comments!
