Note: X-ref'ed from this thread http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1348188#Post1348188
Something really seems strange - look at those numbers. This is a CI-4/CG-4/SL oil, but the additive #'s seem awful low. Definitely expecting to see higher everything, especially zinc/phos.
I've seen higher numbers from CJ-4/SM's.
Maybe we worry too much.
Here are Blackstone's comments:
RON: The viscosity of this virgin oil sample was typical for this oil type and grade. It did not contain any water or insolubles. The additive levels were properly balanced, but a bit low compared to most other 15W/40's (this is not necessarily a problem, unless you have reason to believe it is) WTH does that mean?. This clean, dry oil appears suitable for use. The TBN was 10.4, which is appropriate for this type diesel engine use oil.
UOA #——–
MI/HR ON OIL: —–
MI/HR ON UNIT: ——
DATE: 1-30-09
ALUMINUM: 0
CHROMIUM: 0
IRON: 1
COPPER: 0
LEAD: 0
TIN: 0
MOLY: 1
NICKEL: 0
MANGANESE: 0
SILVER: 0
TITANIUM: 0
POTASSIUM: 0
BORON: 1
SILICON: 3
SODIUM: 2
CALCIUM: 693
MAGNESIUM: 532
PHOSPHOROUS: 676
ZINC: 816
BARIUM: 0
SUS VISC. @210F: 76.0
Cst Visc. @100C: 14.50
Flashpoint: 425
Fuel %: —
Antifreeze %: —
Water %: 0.0
Insolubles %: 0.0
TBN: 10.4
TAN:
ISO Code:
I shook the heck out of the bottle before I took the sample so everything should be mixed up in there; maybe I didn't shake it enough?
Blackstone's equipment out of calibration?
Maybe I'll shake it even harder/re-send?
Send somewhere else? Recommendations?
Not worry about it? It's for my bro's tractor, after all, and I know the J-D stuff http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1062417#Post1062417 I use in mine is good.
UOA #——–
MI/HR ON OIL: —–
MI/HR ON UNIT: ——
DATE: 1-30-09
ALUMINUM: 0
CHROMIUM: 0
IRON: 1
COPPER: 0
LEAD: 0
TIN: 0
MOLY: 1
NICKEL: 0
MANGANESE: 0
SILVER: 0
TITANIUM: 0
POTASSIUM: 0
BORON: 1
SILICON: 3
SODIUM: 2
CALCIUM: 693
MAGNESIUM: 532
PHOSPHOROUS: 676
ZINC: 816
BARIUM: 0
Flashpoint: 425
Fuel %: —
Antifreeze %: —
Water %: 0.0
Insolubles %: 0.0
TBN: 10.4
TAN:
ISO Code:
