Taurus question
by Lubener
6 minutes 29 seconds ago
Lucas Extreme Duty CLP?
by Ws6
23 minutes 25 seconds ago
Pennzoil Ultra 5w20 / 7500mi / '08 Ford Fusion 3.0
by sdude2k2000
Today at 12:59 AM
Hairline Cracks in Radiator
by Merkava_4
Today at 12:05 AM
Super Tech Syn 5/30
by RevRider
Yesterday at 11:31 PM
Installing a dish washer.
by ram_man
Yesterday at 10:37 PM
Strangest Three Wheel Car Ever
by Fsharp
Yesterday at 09:57 PM
Remove Gasoilne and other Blowby Gasses
by landtoy80
Yesterday at 09:48 PM
Trans Am said goodbye to his battery today.
by ls1mike
Yesterday at 09:39 PM
Lil Big Rig - I want one
by montero1
Yesterday at 09:01 PM
[Cut Open] Champ PH2808 - Torn Pleat
by Bud_One
Yesterday at 08:41 PM
2015 silverado dealer oil change
by Realtech214
Yesterday at 08:27 PM
robco, TrogDorInjection, wytenow, maxud, OrchardAuto
56875 Registered Users
27 registered (dlundblad, Char Baby, B320i, an3_bolt, 5 invisible), 511 Guests and 206 Spiders online.
56875 Members
66 Forums
244480 Topics
#1316949 - 12/19/08 06:41 PM Husky snow blower engine locked up
bigsteve Offline
Loc: Massachusetts, plymouth county
Friend called today said his snowblower new from last season with only 3 hours on it was blowing oil out the carb area. Went over after work and noticed the dip stick was reading high on the oil level. So we dumped the oil that was pretty dirty and topped it off with Valvoline 5w30. Started engine no oil blowing out but the throttle was stuck on high rmp,proberly gumed with varnish. Anyway before we could shut it off there was a loud noise no equipment owner wants to hear and the engine stoped. I'm guessing that the engine was not over filled with oil but that he left gas in the thank and the needle must have stuck and let gas into the oil? Is there any way I could tell if this is what happened?
#1316954 - 12/19/08 06:45 PM Re: Husky snow blower engine locked up [Re: bigsteve]
Pete591 Offline
Loc: Michigan
Overfilling oil can actually starve the engine as it foams and froths. You need a nice splashing!
Hope that's not the problem.
#1316955 - 12/19/08 06:45 PM Re: Husky snow blower engine locked up [Re: bigsteve]
MolaKule Offline
Loc: Iowegia - USA
CAn you rotate the crankshaft to see if the piston locked up?
Monday Plan: Drink coffee, be awesome, and ignore negativity. smile
#1316980 - 12/19/08 07:09 PM Re: Husky snow blower engine locked up [Re: MolaKule]
Bror Jace Offline
Loc: Saratoga, NY
Have him pull the spark plug and look into the hole with a flashlight. Try to look in while someone else slowly pulls the machine over. If it still turns, he probably holed a piston and the damage may be visible.
If it doesn't, I'm guessing the rod broke.
--- Bror Jace
2015 Mazda 3 iSport
2005 Honda S2000
#1316986 - 12/19/08 07:19 PM Re: Husky snow blower engine locked up [Re: Bror Jace]
ksJoe Offline
Loc: Ks
When I've seen that happen on engines, there is a lot of gas in the oil. Just smell the oil. If that's what happened there is probably more than enough to smell it.
Or dip a screwdriver in the oil and (far away from anything flammable) touch a lighter to it. If there's much gas in it, it should burn.
#1317010 - 12/19/08 07:41 PM Re: Husky snow blower engine locked up [Re: ksJoe]
bigsteve Offline
I drained the oil in a downey container it does not smell like gas but does have a spring fresh sent. I put some oil in a bear bottle cap and tried to light it 5 times with no luck.My friend said that he never put any oil in it just what was in there when he got it. I would say that when I checked it the oil level reading was twice as high as the full mark and that was after he ran it and oil was blowing out of the machine.
Also the engine will not turn over at all with the pull start.This is also the flat head tecumseh engine not sure if that matters.
Edited by bigsteve (12/19/08 07:44 PM)
#1317102 - 12/19/08 09:22 PM Re: Husky snow blower engine locked up [Re: bigsteve]
Pete591 Offline
Loc: Michigan
Pop the head cover off and take a look see..easy to do.
