Any audio gear junkies here?
by BeerCan
23 minutes 53 seconds ago
FRAM XG7317 Cut Open After Street and HPDE Use
by HX520W
Today at 03:05 PM
Emergency declared on 2 California wildfires
by HTSS_TR
Today at 02:46 PM
Scratched interior plastic woodgrain trim
by TmanP
Today at 02:32 PM
Kia Sedona oil leak
by surfbum
Today at 02:19 PM
Castrol Australia's take on the issue with Zddp
by FordCapriDriver
Today at 02:09 PM
A Car Dear to my Heart - Gordon Murray F1 Designer
by HTSS_TR
Today at 02:08 PM
Need clarification regarding toe alignment.
by ST2008
Today at 02:04 PM
Engine Oil in Crusader Engines
by carverguy11
Today at 01:30 PM
How did your pro-rated battery warranty work out?
by CharlieBauer
Today at 12:56 PM
what grease every one using on ball joint ....
by MetalSlug
Today at 12:48 PM
How's Spectro oil?
by jkhawaii
Today at 12:45 PM
uicgrad, snydercn, surfbum, Tmemz4, woollum86
58613 Registered Users
88 registered (Al, Alfred_B, AlienBug, ABerns, 8o8is, AIRJAC3, 6 invisible), 2027 Guests and 11 Spiders online.
58613 Members
66 Forums
252324 Topics
Page 1 of 3 1 2 3 >
#1276512 - 11/07/08 01:20 AM How tight is too tight for oil filter?
crazyoildude Online   content
Loc: New Jersey
I have noticed that many people tighten their oil filters like they are putting lug nuts on their wheels... I even see that with a local ford dealer especially on the 4.6 litre 820s filter is there something i am missing here? I would love to here from everyone on this subject.. We had one on a f-150 today that we had to use an extension breaker bar to loosen it and yes we were turning it counter clockwise.
The other extreme is leaving it too loose which may be worse i see that too.
Will Not Use Oil Filters With Those Tiny Restrictive Looking Louvers! Also Not A Fan Of Oil Jugs That Don't Have A Security Inner Seal..
#1276541 - 11/07/08 03:30 AM Re: How tight is too tight for oil filter? [Re: crazyoildude]
kingrob Offline
Loc: NC
As far as Ford 4.6's go, I had my Crown Vic serviced at the dealer once while it was getting warranty work done, went to change the oil the next time and couldn't remove the drain pan bolt or the oil filter. Breaker bars were no help either.
Went back to the dealer and they refused to touch it, saying that they may strip the pan getting the bolt off. I stood there like an a-hole and told them I wasn't going anywhere until they got the bolt and filter loose.
Finally the manager came out and I told him what happened. He inspected the drain bolt and put a wrench on the filter. He couldn't budge either one.
He called out the guy that changed the oil on my car previously and told him we wasn't to leave until he put got them loose. The guy looked like a drooling retard with severe emotional problems. About an hour I came back and the guy said he had everything loose. I told him to keep it on the lift, I wanted to inspect it before I left. He balked, but I'm one of those guys that can be pretty persuasive when pi**ed. Looked up under there and danged if it wasn't the same exact filter and drain bolt. He hadn't done anything to it.
I called the manager out and he acted like he didn't believe me at first, then put a socket and breaker bar to the bolt and it wouldn't turn. Same with the filter.
After it was all over with I ended up with a new oil pan, drain bolt, and filter. Somebody with an IQ over 85 must have replaced both because they both came off pretty easy that time.
Somewhere in that craziness one of the guys ended up breaking my drivers side door handle from the inside and getting grease all over my leather. Instead of taking it back there I replaced the handle myself and did what I could to get the oil stains out of my upholstery. In my experience, Dealership service departments are no better than the typical Jiffy Lube or Wal-Mart IMHO.
Nosferautic Wizard Clean 3000
It's magic for your motor!
#1276561 - 11/07/08 05:02 AM Re: How tight is too tight for oil filter? [Re: kingrob]
ZZman Offline
Loc: Michigan
I have never had a problem when putting one on hand tight. By that I mean turning by hand till tight. I do not "strain" to tighten it.
I think using a wrench fools you into tightening them too tight as you can't "feel" how tight it is.
2002 Buick Regal GS (3.8 Supercharged) PP, Pure 1 filter
2008 Sebring Hardtop convertible (2.7) PP, Pure 1 filter.
2006 Kawasaki Vulcan 900 LT
#1276563 - 11/07/08 05:07 AM Re: How tight is too tight for oil filter? [Re: ZZman]
demarpaint Offline
Loc: NY
I've always found that some people tend to complicate installing an oil filter. Over the years whenever I had a shop do an oil change I cursed them the next time I did the change. Either the drain plug was tightened like a lug nut, or the filter had to be removed with a big Channel Lock Plier, or stabbed with a screw driver!
I put the filter on by hand, then give a 1/4 turn with a wrench, that's it. Now well over 30 years I never had a problem getting one I installed off, and never had one leak.
Frank D
God Bless Our Troops
#1276600 - 11/07/08 07:11 AM Re: How tight is too tight for oil filter? [Re: demarpaint]
cowhorse01 Offline
Loc: Oceanside, California
What Frank said....hand tight, then 1/4 turn with an oil filter wrench, THAT'S IT. No more.....
Byron
1997 F-350, 7.3 PSD, Heavily Modded, Rotella T 15w-40
2015 Kia Soul Plus
2012 34' Sundance by Heartland TT
#1276612 - 11/07/08 07:33 AM Re: How tight is too tight for oil filter? [Re: cowhorse01]
TallPaul Offline
Loc: By Detroit
I wonder if the manufacturer gives a torque specification for oil filters. Maybe not applicable because of the rubber gasket. Anyway tightening a filter is a feel thing and generally the filter says 3/4 turn after gasket hits mounting flange, but I find it pretty hard to hand tighten to 3/4 turn.
I have had shop oil changes where next time I could not get the filter off without a lot or extra effort. One shop put the drain plug in so tight I got a sore arm pushing on the box end wrench to get it off and my wrench was probably 9 inches long. There are a lot of ham fisted boneheads out there doing oil changes. Always do yourself. Another option with the filter is mount a bracket or use an existing bracket to tie back the filter (hose clamp around filter holding a heavy wire to the bracket so filter can't rotate).
The masses, thirsting for convenience, unwittingly dig the grave of the automobile as we knew it. The industry already has one foot in that grave.
#1276619 - 11/07/08 07:44 AM Re: How tight is too tight for oil filter? [Re: crazyoildude]
FZ1 Offline
Loc: Texas
When in doubt;Torque it out! I use a torque wrench on all my motorized vehicles.
#1276649 - 11/07/08 08:44 AM Re: How tight is too tight for oil filter? [Re: FZ1]
02zx9r Offline
Loc: Ball, LA
too tight for me is when you torque the [censored] out of it and oil leaks everywhere
2012 Honda Insight EX
#1276674 - 11/07/08 09:21 AM Re: How tight is too tight for oil filter? [Re: demarpaint]
Bircsbor Offline
Loc: Canada
^+2 , although using my old band wrench on the VQ in the Altima is a challenge, so I just picked up a ratchet mount filter wrench that uses cams to operate 4 "fingers" to grip the filter. Only 1000miles till I get to test this new mouse trap. I used to do just hand tight...but arthritis makes that unreliable now.
03 Nissan Altima 3.5SE PP 5w30 w/ OEM Filter
00 VW Beetle GLS On-sale syn w/ Fram Filter
01 Honda Foreman 450ES Amsoil 0W40 w/OEM Filter
#1276678 - 11/07/08 09:33 AM Re: How tight is too tight for oil filter? [Re: Bircsbor]
Cutehumor Offline
Loc: USA
I do hand tight. I have tighten the oil filter too tight before and it was a pain to remove when it was time to change the oil. most shops do it tight with a oil filter wrench to avoid liability if it pops off somehow
09 Chevy Cobalt 2.4L 88k miles Peak 5w30
09 Pontiac Vibe 2.4L 98k miles Pennzoil platinum 5w30
#1276753 - 11/07/08 11:38 AM Re: How tight is too tight for oil filter? [Re: crazyoildude]
EagleFTE Offline
Loc: St. louis
Been changing my oil for about 30 years now and for last 10 - 15 I typically have had four vehicles so I do a fair amount of oil changes. I hand tighten only on filters and have not had any problems. I do wash my hands before tightening the filter to make sure I have a good grip. I bought a used vehicle last year and the speedy lube place that had last serviced it put the filter and drain plug on way too tight. I had to resort to a large wrench and a dead blow hammer for the plug. I don't know why someone would crank that hard on it.
#1276801 - 11/07/08 12:34 PM Re: How tight is too tight for oil filter? [Re: EagleFTE]
Spawne32 Offline
Loc: NJ, USA
more then likely they used an air ratchet on the drain plug, but yes i have seen that, my brothers ex-gf's car had the oil filter on there so tight we destroyed the oil filter wrench trying to get it off, as well as the filter, i dont know how they could have gotten the filter on that tight but they did. I even had a shop air gun spark plugs on my old car.
Edited by Spawne32 (11/07/08 12:34 PM)
#1276847 - 11/07/08 01:21 PM Re: How tight is too tight for oil filter? [Re: Spawne32]
TallPaul Offline
Loc: By Detroit
Bonehead at the qickie lube has one car come back with dripping from the drain plug and from then on he tightens the [living censored] out of the things.
#1276880 - 11/07/08 02:12 PM Re: How tight is too tight for oil filter? [Re: Spawne32]
kingrob Offline
Loc: NC
Wow, airgunning sparkplugs, WTF!
From what I've seen in places "specializing" oil changes, heck most every Shop, period; airgun on the drain pan bolt is the RULE rather than the exception. I asked a guy once why he did that, he said it took too long to do it with a socket wrench. I said, what an extra ten, twenty seconds? He just glared. Laziness is what it was.
Another guy told me he did it because all the other shops did it and it was impossible to get it off by hand. So, why don't you just use an airgun to get it off, and a wrench to put it back on? Once again, it took too long to use two different tools. Laziness, and lack of sympathy for the DIY-er who goes to get it off the next time.
#1276918 - 11/07/08 02:44 PM Re: How tight is too tight for oil filter? [Re: kingrob]
ted s Offline
Loc: Albany NY
hand tight.
Page 1 of 3 1 2 3 >
