Troybilt TB110 won't start
by Capa
05/25/13 08:03 AM
Straight 30 weight during summer
by GreeCguy
05/25/13 07:59 AM
Amsoil Study of SAE 5W-30 Synthetic Motor Oils
by TheFatMan
05/25/13 07:52 AM
Break in oil
by GreeCguy
05/25/13 07:35 AM
New member, I'm glad I stumbled into this place!
by Biggles
05/25/13 05:30 AM
Surf City garage barrier reef products?
by Rolla07
05/25/13 12:17 AM
24 Quarts Honda 0w20 SM Idemitsu
by Cooper
05/24/13 11:48 PM
MC 0W-20 SynBlend FF, 2200 mi, 13 Mustang 5.0
by mahler206
05/24/13 11:13 PM
$1.99 Formula Shell at Menards.
by Topo
05/24/13 10:42 PM
2012 Ram 3500 6.7 Cummins
by hollnagelc
05/24/13 10:23 PM
Fleet Farm Havoline $1.59/Mystic $1.99 Qt MMIR
by MDS
05/24/13 10:03 PM
Lower oil pressure at startup than when warm?
by Cperk
05/24/13 10:02 PM
TheBiggRooster, btbeme, SideSwipe, Eddie2390, b3av3r
45552 Registered Users
84 registered (05LGTLtd, 72Cude426, 825ltrgt, 1999cutiger, 123Saab, 05foresterXT, 10 invisible), 1277 Guests and 237 Spiders online.
45552 Members
64 Forums
193917 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1253873 - 10/09/08 04:34 PM Code PO128- Thermostat??
exranger06 Offline
Loc: Guilford, CT
My sister has a 2001 Saturn L200. The check engine light recently started coming on, so she takes it to Autozone and has them scan for codes. They came up with code PO128, "Engine coolant temp below thermostat temp."
I'm probably gonna replace the thermostat regardless, as I feel it's be a good maintenance thing to do. The only other thing I could possibly think of is maybe the coolant temp sensor. She said the fans were turning on even when it was really cold outside, which I think is probably normal, but it's also possible.
Anyone do a thermostat on one of these before? I know thermostats are generally very easy but I've never done one before, on any car. Any advice/insights/suggestions are very much appreciated.
Also, the thermostat located right where the upper radiator hose connects to the engine right? I know on most cars it is but this Saturn has some strange design elements from what I've seen so far.
Edited by exranger06 (10/09/08 04:43 PM)
2006 Ford Ranger Sport -45k mi- Napa syn 5w-30
1994 Ford Explorer Sport -178k mi- Napa conv. 5w-30
1992 Honda Accord EX -163k mi- Napa syn 5w-30
#1253892 - 10/09/08 05:05 PM Re: Code PO128- Thermostat?? [Re: exranger06]
03cvpi Offline
Loc: Minneapolis
Fairly easy. Mouted on the front of the engine towards the pass side of the car. Don't loose the cardboard tube. The thermostat is pushed in and quarter turn to lock. If you have a mech mirror it's pretty easy to see. Most replacement t-stats come with the tube, if not a needle nose pliers will work, but on install be careful not to crush the t-stat.
#1254329 - 10/10/08 09:46 AM Re: Code PO128- Thermostat?? [Re: 03cvpi]
eljefino Offline
Loc: ME
^ That sounds right for a 1.9, is it the same for a 2.2 ecotec or 3 liter V6?
The fans will run when the car is cold if the AC is on, even as part of the defroster. If there's a CTS fault forcing the fans on there'll be a code for that too.
Diagnosing this much farther will probably take more time than the thermostat job. My experience with GM's is they usually fail cold, which is a good failsafe. \:\!
#1254527 - 10/10/08 02:42 PM Re: Code PO128- Thermostat?? [Re: eljefino]
mechtech2 Offline
Loc: Chicago Area
Make sure the mating surfaces are clean and corrosson free.
I am a fan of using a LIGHT coat of silicone RTV on gaskets and 'O' rings - no comebacks.
You may have a sensor problem. If the thermostat does not fix the problem, look there.
