45437 Members
64 Forums
193543 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1194478 - 07/15/08 04:14 PM
Re: Amsoil SSO 0W-30, 1993 Civic, 3,007 miles
[Re: harry j]
Loc: The Rocky Mountains
Good to see you got that taken care of harry j! Now you can start down the path of the extended drain  . SSO is a rock solid product and I can't wait to see how it does at the 15k mile mark.
Used gear lube and burnt ATF is all the cologne a real man will ever need! Too many toys and automotive parts to list...
#1204484 - 07/29/08 08:30 PM
[Re: harry j]
Loc: MD
Did you ever get the antifreeze leak fixed? If the leak was so minor that you never notice the level go down then the coolant tabs or a big bottle of liquid barsleak should have taken care of it. I have seen that stuff eliminate some serious leaks before.
#1204696 - 07/30/08 06:00 AM
[Re: harry j]
Loc: South Texas
BTW, I have decided, based on 6 UOAs, to change the EAO every oil change. The ISO oil cleanliness code jumped 2 or 3 numbers when I left the used filter in place, for example 17/17/14 vs 15/15/12 with a clean one. Have all 6 UOAs been done at about 3k and are you going to share the results? It would be interesting to see the trending even though your engine has had some fuel/coolant issues.
07 Pilot PP 5W-20 33,600 RP OF Fram AF
93 Civic RTS 5W-40 215,400 RP OF OEM AF
#1204726 - 07/30/08 07:25 AM
[Re: jmsbntz]
Loc: Jupiter, FL
BTW, I have decided, based on 6 UOAs, to change the EAO every oil change. The ISO oil cleanliness code jumped 2 or 3 numbers when I left the used filter in place, for example 17/17/14 vs 15/15/12 with a clean one. Have all 6 UOAs been done at about 3k and are you going to share the results? It would be interesting to see the trending even though your engine has had some fuel/coolant issues. Yes, all UOA's have been done at close to the 3,000 mile mark. I will get the information together and post them as soon as I get a chance.
#1204728 - 07/30/08 07:28 AM
[Re: ProStreetCamaro]
Loc: Jupiter, FL
Did you ever get the antifreeze leak fixed? If the leak was so minor that you never notice the level go down then the coolant tabs or a big bottle of liquid barsleak should have taken care of it. I have seen that stuff eliminate some serious leaks before. So far, I have resisted adding anything to the antifreeze. The coolant level has not changed at all, so I am thinking that it could be a residual left over from a recent head gasket failure. I am going to moniter the situation and see if perhaps the potassium level starts to dimish with subsequent OC's.
#1204897 - 07/30/08 11:35 AM
[Re: harry j]
Loc: NJ
cSt Viscosity-8.81---9.31-----9.21-------9.41------9.56 Flashpoint----355----425------345--------385-------370 Fuel dilution is impacting the viscosity. Do you plain on running it longer? Tbn is strong. For 3k mile drains, I think any cheap 5w20 could handle it.
#1205109 - 07/30/08 04:47 PM
[Re: harry j]
Loc: NJ
What do you think about the new Amsoil racing oils? I'm sure they are very good.
#1205150 - 07/30/08 05:31 PM
[Re: buster]
Loc: Las Vegas NV
I'm not an expert on ISO codes, but all of those results appear to be very clean, filter reuse or not.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#1205656 - 07/31/08 10:31 AM
[Re: Tempest]
Loc: Jupiter, FL
I'm not an expert on ISO codes, but all of those results appear to be very clean, filter reuse or not. Yeah Tempest, it's the EAO filter, totally awesome! If you can get past the cost of this superb filter, it beats any filter now available by a wide margin. Unless something comes along that's better, I will not even consider putting any other filter in my Civic. I'm thinking that the EAO specs can be improved on if they use more nano fiber material. I would love to see, say, a 12,000 mile filter that allows good oil flow and cleans even better than the present EAO.
#1205953 - 07/31/08 04:49 PM
[Re: harry j]
Loc: Las Vegas NV
I think buster went 27K miles on one over several OCI. All the UOAs came back good. I've got around 15K on mine with 3 OCI...forgot the actual number...
