Originally Posted By: aquariuscsm
Is double clutching:
Accelerate in 1st,depress the clutch pedal,shift into neutral,release the clutch pedal,re-depress the clutch pedal,shift into 2nd?
Is that the basic principal? They discuss double clutching on Twinturbo.net all the time for people with bad synchros in their trannies to avoid gear crunch.
That is almost correct, but it is used mainly in downshifting situations, if you have to double clutch to upshift in a synchromesh tranny I would suggest buying a new transmission. The procedure for downshifting (say 3rd to 2nd for example) is to push clutch in and pull shifter into neutral from 3rd. Release clutch, then hit accelerator pedal and build revs up quickly (usually 3k-4k range), push in clutch again and then pull shifter into 2nd gear, release clutch with a bit of accelerator pedal to rev match. Once you get good at it, you can do the entire procedure in a fraction of a second and you know that you got it right when the shifter just falls into 2nd gear like nothing. I usually double clutch on downshifts into 2nd, not so much in higher gears. Double clutching also helps alot with down-shifting into first gear while the vehicle is moving, some cars are very notchy shifting to first when the vehicle is moving, double clutching makes it much easier.
BTW, rev matching is just applying accelerator pedal as you release the clutch, making the transition smooth by getting the rpms up a bit. If you don't rev match when releasing the clutch on a shift then the engine braking can cause a jerky motion as it wants to decelerate. Rev matching and double clutching are two different things, though often used together.
