left most sample is GC (the newer gold kind, not the old green kind), right two samples are rotella T 15W40
couple of things i found interesting:
1 ) wear numbers are pretty much the same. the right most sample of rotella was used a track day, the middle sample of rotella is pure commuting, the left sample of GC was used in commuting and some 'mountain' driving
2 ) GC seems to have slightly higher than expected viscosity compared to other 30 weights.. any one else see this?
3 ) a some manganese.. i think this is because i'm using a 50%/50% mix of 91 octane and 100 octane to make deto go away.. previous samples had 100% 91 octane fuel
what do you guys think? I think i might stick with rotella T since its much cheaper than a synthetic oil and looks to be doing as good of a job protecting the engine
EDIT: I was planning on doing 3 samples of Rotella T versus 3 samples of GC but I forgot to get an oil sample for the third rotella change.. i have GC in the car again right now.. so at least i'll have a 2 sample comparison to base future decisions on
