45901 Members
64 Forums
195312 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1090585 - 02/21/08 02:48 PM
Oil for 2007 Dodge Sprinter 2500 3.0L 6-cyl Diesel
Loc: UTAH
I am going to change the oil on my Dodge for the first time and wanted to know if anyone here has some recomendations for me.
Looking in the manual I am required to use an oil that meets the Mercedez_benz spec oil sheets MB228.51, 229.31 or 229.51. Personally I do not know what these are, hence my request on this forum.
I live in Utah and have cold winters so I would like to go with a thin winter weight and also want better gas mileage so want to go with a thin operating temp weight also. I am thinking a 0W-30 or a 5W-30 oil.
The manual gives this warning for the diesel "Never use any amount of engine oil for the diesel engine that does not conform to MB 229.51 or 229.31 specifications. Otherwise the diesel particle filter (DPF) could be damaged."
Thanks in advance for any help.
#1090610 - 02/21/08 03:52 PM
Re: Oil for 2007 Dodge Sprinter 2500 3.0L 6-cyl Di
[Re: cmanser]
Loc: Retired | Wausau, WI
Edited by Johnny (02/21/08 03:53 PM)
#1090615 - 02/21/08 03:57 PM
[Re: Johnny]
#1090617 - 02/21/08 04:09 PM
[Re: Johnny]
Loc: UTAH
Wow - 3 answers from the same poster - Thanks. I looked at the link on the 0W-40 and it has these certs. Mobil 1 0W-40 has the following builder approvals: 0W-40 MB-Approval 229.3 X MB-Approval 229.5 X I need the 229.31 or 229.51. It says in an emergency I can add 1 qt of 229.3 or 229.5 but ONLY 1 quart max can be added. The 5W-40 has the Mercedes Benz 228.5 X - again - not what I need. Thanks Johnny - and I appreciate the welcome!! http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-40.asp  to BITOG
Edited by cmanser (02/21/08 04:11 PM)
#1090624 - 02/21/08 04:19 PM
[Re: cmanser]
#1090627 - 02/21/08 04:24 PM
[Re: Johnny]
Loc: UTAH
VERY NICE - thanks Johnny - now, where can I find this??? I called around and no one carries this...
#1090631 - 02/21/08 04:27 PM
[Re: cmanser]
Loc: Middlesex County CT
Mobil 1 ESP. You can get from avlube in ohio or maybe at the dodge dealer.
edit: apparently someone beat me to it.
Edited by simple_gifts (02/21/08 04:29 PM)
2003 Echo, >308K, Supergard(sic) 5W-20 and a white can. 2006 B2300, 75K,ALM
#1090635 - 02/21/08 04:36 PM
[Re: cmanser]
VERY NICE - thanks Johnny - now, where can I find this??? I called around and no one carries this... I sent you a PM on this.
#1091942 - 02/23/08 05:35 PM
[Re: Johnny]
Loc: Washington
https://www.amsoil.com/storefront/afl.aspxEuropean Car Formula Synthetic 5W-40 Motor Oil (AFL) about the easiest to obtain in US. Mercedes warranty dept can be difficult about oil specs and required maintenance periods with any engine failure that oil may be involved.
#1098087 - 03/03/08 04:09 PM
[Re: Steelhead]
Loc: UTAH
Ended up going with the Mobil 1 ESP 5W-40.
Dodge recommends 10k OCI on this vehicle - I did the change at 10k and the oil was tar black. I am talking VERY black. I think next time I will try an 8k OCI.
Thanks for the advice.
#1098141 - 03/03/08 05:56 PM
[Re: cmanser]
Loc: Florida
Diesel engines turn the oil much darker, due to the soot in the oil. The only way to prove that the OCI is too long is to send it to an oil analysis lab.
2010 Lancer Ralliart Sportback
#1098400 - 03/04/08 01:02 AM
[Re: artificialist]
Loc: NV
Was that your first oil change? Usually the first one you should do at 500-1000 miles. Diesel oil will turn very black in some engines. You should see our '83 Benz 240D. No matter how many times you change that oil, it will still be pitch black, even right after an oil change. It's normal. My Cummins on the other hand never really turned the oil black. After I added a Frantz bypass, my oil is now amber colored every time I pull out the dipstick. It still blows my mind. You may want to consider that as well.
1996 Dodge Ram, 12v Cummins, 4x4, 47RE, ext. cab, long bed
#1098583 - 03/04/08 11:06 AM
[Re: cmanser]
Loc: Everett,Wa.
Thanks for the advice. The Black oil is thanks to the new emmisions on the diesels. I have an '07 5.9 Cummins and the oil is Black about 2 minutes after I change it.
#1099453 - 03/05/08 02:09 PM
[Re: Stewart Fan]
Loc: Europe
