super tech conventional
by grease_monkey
4 minutes 21 seconds ago
what are some thoughts on toyota 0w-20 oil?????
by whitearrow
18 minutes 49 seconds ago
castrol syntec blend opinions please
by mozart
25 minutes 11 seconds ago
2007 Malibu 3.5L (LZ4) Q-HP 5w30
by Nyquist
35 minutes 13 seconds ago
Super S motor oil
by Panzerman
58 minutes 12 seconds ago
BMW OEM vs Mann vs Mahle vs Hengst
by fcbuff
Today at 05:14 PM
GC vs BMW 5W30 in X5 3.0L...
by fcbuff
Today at 05:11 PM
Where did ARX, GC, and Havoline go?
by J. A. Rizzo
Today at 04:49 PM
tcurtis, rsigner, motuman, jessh, biffleg
30211 Registered Users
135 registered (90crvtec, 1969, 77GrandPrix, 2003f7, 07GreyLBZ, 7 invisible), 481 Guests and 15 Spiders online.
30211 Members
60 Forums
123765 Topics
Max Online: 728 @ 01/04/10 06:48 PM
#1062417 - 01/11/08 01:19 PM John Deere Supreme "Plus 50" 0W-40
RWEST Offline
Loc: Somerset County, PA
A VOA on J-D's semi-syn 0W-40 that I've just recently started using in my J-D X595 tractor (24 HP 3 cyl. Yanmar diesel).
RON: Everything looks fine in this sample of virgin 0W/40 oil. The TBN starts out strong at 9.4, which is a common reading for a new diesel use oil like this. The additive package is also strong and should do well in your tractor. No water or insolubles were found. The iron isn't a problem and neither is the silicon. Silicon at this level may be from a little anti-foam additive. The viscosity was right in the middle of the 40W range, though that will drop a little after the oil sees use (like it does with all oils). In any case, this oil is perfectly serviceable.
ALUMINUM: 0
CHROMIUM: 0
IRON: 2
COPPER: 0
LEAD: 0
TIN: 0
MOLY: 94
NICKEL: 0
MANGANESE: 0
SILVER: 0
TITANIUM: 0
POTASSIUM: 0
BORON: 123
SILICON: 4
SODIUM: 2
CALCIUM: 2659
MAGNESIUM: 289
PHOSPHOROUS: 1226
ZINC: 1416
BARIUM: 0
SUS VISC. @210F: 76.9
Cst Visc. @100C: 14.73
Flashpoint: 425
Fuel %: —
Antifreeze %: —
Water %: 0.0
Insolubles %: 0.0
TBN: 9.4
TAN:
ISO Code:
Interesting that the Blackstone VOA shows a TBN of 9.4. At the J-D page describing the product http://www.deere.com/en_US/parts/partsinfo/oils_and_lubricants/oil_0w40.html they note a TBN of 12.8. Seems like quite a difference!!
"even if you're paranoid, they can still be following you" hide
"live so the preacher doesn't have to lie at your funeral" wink
#1062432 - 01/11/08 01:36 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: RWEST]
addyguy Offline
Loc: Canada
Even with the TBN discrepency, I'm still really impressed with this oil! Love that add-pack with moly and boron. This oil 'looks' a lot like M1 0W-40, the add pack seems similar in that it uses both those elements, but it also has the advantage of the high Zinc number.
2002 Chevrolet Cavalier, 2.2 OHV, Auto, 137k miles.
Petro-Canada Supreme 5W-30; Purolator oil filter; Motomaster air filter.
#1062531 - 01/11/08 04:42 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: addyguy]
RWEST Offline
We're looking at stocking up on this for our other J-D diesel equipment as well, especially since the local J-D guy is having a January lube/filter sale right now.
We'd been using Rotella "T" 5w-40, but, the numbers from this http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1040289#Post1040289 VOA seems to show the "T" getting a bit weak in the ZDDP's as it were. Maybe we're over-worrying about nothing as regards the T's numbers, but, those J-D diesels aren't cheap to fix. We'd really rather not take a chance.
Hmmm. I have a stash of CI-4+ "T" 5-40, maybe I'll send some of that out for a VOA before I hide from the falling sky.
#1209032 - 08/05/08 05:56 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: RWEST]
pickled Offline
Loc: The Rocky Mountains
Bump
Used gear lube and burnt ATF is all the cologne a real man will ever need!
Too many toys and automotive parts to list...
#1231299 - 09/06/08 08:54 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: pickled]
daman Online   content
Loc: Bad Axe, MI
How much is this oil??
"Always"..Mobil 1
Current fill 0w30 Green Cap
#1234152 - 09/11/08 03:08 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: daman]
RWEST Offline
Sorry daman, just worked my way back here. J-D lubes seem to vary dramatically in price, based on your location. Here in SW PA, the last I checked, 0W-40 runs between $4.50 and $5.50/qt, depending on whether you buy it by the quart or in 5 gallon buckets.
#1234247 - 09/11/08 05:58 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: RWEST]
Finklejag Offline
Loc: Portland, OR
So who makes this oil?
#1234760 - 09/12/08 01:58 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: Finklejag]
RWEST Offline
Esso Imperial, Canada, per the J-D MSDS sheet http://eservice.msds.com/servlet/SSMain
#1235440 - 09/13/08 04:31 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: RWEST]
Loc: Bad Axe, MI
Not to bad if it's turns out to be a good oil..
"Always"..Mobil 1
#1236195 - 09/15/08 08:03 AM Re: John Deere Supreme "Plus 50" 0W-40 [Re: RWEST]
Loc: Bad Axe, MI
Really??
should make for a great oil then?????
"Always"..Mobil 1
#1236237 - 09/15/08 09:20 AM Re: John Deere Supreme "Plus 50" 0W-40 [Re: RWEST]
Loc: Bad Axe, MI
Am i missing somthing?, i'm showing;
Chevron Texaco Global Lubricants
Chevron Texaco Global Lubricants (Chevron Pdts Lubricants & Specialty Pdts) US
and i'm reading a semi-synthetic, JD web site sounds like a full syn.?
"Always"..Mobil 1
#1237589 - 09/17/08 11:01 AM Re: John Deere Supreme "Plus 50" 0W-40 [Re: daman]
RWEST Offline
daman -
At their MSDS site http://eservice.msds.com/servlet/SSMain using Keyword "plus-50 0w-40 oil"
I got
1 John Deere Plus 50/Supreme Engine Oil 0W-40
Esso Petroleum Canada/Esso Imperial Oil/Pétrolière Impériale MSDS/SDS
2003-07-04
English 1182099
You're right - the J-D site says "100 percent synthetic base oil", but the bottle I have under my desk (I like to keep one handy!!!) says "synthetic blend". I dunno??
#1246390 - 09/29/08 08:30 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: RWEST]
Loc: Bad Axe, MI
daman -
I got
2003-07-04
English 1182099
Hmmm, ok thanks \:\!
"Always"..Mobil 1
#1767688 - 02/03/10 11:13 PM Re: John Deere Supreme "Plus 50" 0W-40 [Re: daman]
brow Offline
Loc: Alberta, Canada
Stupid question - would this oil be OK on my 5.7L Toyota gasser? It's an '07 Tundra, calls for 0W20 but dealer puts in 0W30.
'07 Toyota Tundra
'07 Honda Odyssey
#1767935 - 02/04/10 07:46 AM Re: John Deere Supreme "Plus 50" 0W-40 [Re: brow]
Loc: Bad Axe, MI
i think it would be a great choice,if your outa warranty sure go for it,mileage may suffer just a bit but besides that no problem,i know a guy running 15w40 in his '05.
"Always"..Mobil 1
