Electrical Gremlin or Voltage Regulator?
by dkryan
04/30/16 06:45 PM
Leaky fuel tank on B&S Quantum enigne
by MI_Roger
04/30/16 05:40 PM
M1 HM or PHM
by car51
04/30/16 05:18 PM
Rotella T6 5W40, 8,000 mi, '09 Cobalt SS 2.0T
by GermanAutohaus
04/30/16 04:37 PM
Accord / Jetta Saturday Detail {PICS}
by gregk24
04/30/16 04:22 PM
MOTUL 8100 X-Cess 5W40, 8,014 mi, '04 Audi A4 1.8T
by GermanAutohaus
04/30/16 04:00 PM
Free Riding Mower Needs a Carb
by Delta
04/30/16 03:41 PM
Rate my lawn plugs
by JHZR2
04/30/16 03:38 PM
Rotella T6 5W40, 14,000 mi, '13 Audi A6 3.0l TFSI
by GermanAutohaus
04/30/16 03:24 PM
#915 over FK1000P?
by Phishin
04/30/16 03:04 PM
Rotella T6 5W40, 6,480 mi, 2015 Ford Explorer 3.5l
by GermanAutohaus
04/30/16 02:46 PM
Rotella T6 5W40, 7,600 mi, 2011 Audi A5 2.0T TFSI
by GermanAutohaus
04/30/16 02:38 PM
Spinnizle, JustinL, abdoezzat, JanK, paydase
57755 Registered Users
85 registered (Bandito440, 2004tdigls, AntsinmyEyes, 07titan, 209paulc, 12 invisible), 1603 Guests and 322 Spiders online.
57755 Members
66 Forums
248267 Topics
#1046936 - 12/15/07 01:28 PM Hydraulic jack won't pump up
Kestas Offline
Loc: The Motor City
My hydraulic jack won't pump up the lift mechanism. The lever mechanism works okay and the unit is full of hydraulic fluid, but it won't pump up. This is a Prolift 3300 lb jack with wheels and the hydraulic pump is mounted horizontally.
I believe it may have air in it that needs to be bled. What is the procedure for bleeding air out of the unit?
This has happened in the past and I've always managed to get it working... but not this time. The unit is over 20 years old, but I don't want to toss it if it's still repairable.
#1046937 - 12/15/07 01:30 PM Re: Hydraulic jack won't pump up [Re: Kestas]
XS650 Offline
Loc: Northern CA
Sounds like a dead seal.
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
--Mark Twain
#1047038 - 12/15/07 05:23 PM Re: Hydraulic jack won't pump up [Re: XS650]
88Dakota Offline
Loc: Massachusetts
From what I remember of the bleeding procedure, you're supposed to loosen the release screw and pump it for a while.
#1047108 - 12/15/07 07:16 PM Re: Hydraulic jack won't pump up [Re: 88Dakota]
SHOZ Offline
Loc: Illinois
Yes it needs bled. I have that problem as mine gets hauled around.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#1047225 - 12/15/07 11:10 PM Re: Hydraulic jack won't pump up [Re: SHOZ]
alreadygone Offline
Loc: North Arkansas
88Dakota's reccomendation is correct. In it's normal position, open valve and pump repeatedly. ten when valve is closed it should work properly.
Bob
To which version of reality would you like to convert me?
Bob
#1047230 - 12/15/07 11:23 PM Re: Hydraulic jack won't pump up [Re: Kestas]
Merkava_4 Offline
Loc: Clovis, CA
A lot of these floor jacks have no rebuild kits available; they're pretty much a throw-away when the seals give out.
I've go an old Taiwanese made 3.5 ton jack that needed some steel balls for the races in the swivel casters. I was so dang stubborn, that I went and found a place that stocked the steel balls I wanted; now it rolls real nice.
