Got a real interesting debate for you guys here........
I run 37's and bigger with a stroker, D44 rear end grenades 3 times in one summer, this summer in fact. I have a high pinion hi clearance Currie Iron Rock Jock D60 in the back now, goodby to rear end issues!!!!! At least I thought....
I've been an absolute believer of synthetics since grade 11 mechanics, and have seen time and time again the benefits of good quality synthetics over mineral. I run Amsoil exclusively, nothing against Mobil, or Red Line, Amsoil is readily available in my small town, other synthetic lines are not.
So what's the point Mike? Currie says they'll void warranty if I run synthetic gear lube!!!!
They recommend 85/140 mineral gear oil, I have that available but it's getting stupid cold here so I got their approval to run 80/90 mineral gear oil, Chevron is the brand, as is the 85/140.
The reasoning why Currie doesn't approve of synthetics? The explanation I was given is that they have had component failure in 9" axles they build which they beleive was a direct result of the synthetic oils used did not, or COULD not, deal with "excessive shear, pressure", and for reasons unknown they believe mineral-based 85/140 offers much better protection.
One guy I talked to earlier this summer, he siad stick with mineral for break in, and I can run my choice of oil, which would be Amsoil severe duty 75/140. Once we began install I talked with another gent that stated all warranty will be void if I did not run approved oil.
So, what do you guy think I should do here. I have no probem running mineral through the warranty if they want that, but even then I'm not sure of the grade. I can use 85/140, but it is getting cold, and that oil is thick.
Should I stick with 80/90 Chevron, or can I switch to 85/10 where it gets -40c/-40f. Keep in mind my Jeep is parked in a heated garage in the winter, and when it's out, it's being driven so it won't be outside for prolonged periods, but it will be parked here and there for 2-3 hour at a time. Will 85/140 hold up to this?
Regarding the synthetic question, most shops building axles use synthetics, why can't I?!?!?
Thanks for the time, discuss!!!!
