Quote:
How did you notice all that stuff? How do piston pins want to seize? what about cylinder wall scuffing?Quote:
I've had better luck with dino oil than synthetic in my Buick. When I switched to synthetic I noticed much more cylinder wall scuffing and piston pins wanting to seize. Switched back to dino and have yet to have the problem again. I change oil every 500-1,000 miles anyway.
When the motor was pulled apart, I could barely rock the piston back and forth on the rod. The pins were just about completely siezed. The cylinders were scored and so were the piston skirts on the thrust surfaces. I tried glass beading the piston skirts which helped but did not eliminate it. I'm sure some of it came from pushing production pieces so hard but it did not happen with dino oil. FWIW I was using 20-50 dino and 15-50 synthetic.
