Quote:
Quote:
sorry but beam type torque wrenches are garbage
That is simply untrue. Beam style torque wrenches work very well and they never lose their calibration unless you REALLY abuse them. Their downfall is that you have to have a good view of the scale and that can be a problem in cramped quarters. Just because a wrench clicks at 150 lbs. doesn't necessarally mean that it is accurate.
Clicker style wrenches are convenient, but you need to be aware that dropping them, leaving the spring tensioned, or just bad luck can leave them out of calibration. You never know - I have a cheapie Great Neck model that tests well against a Snap-on for many years. I know of someone else with a expensive clicker that did $1,000 dollars damage to a tree chipper because the wrench mal-functioned.
The big three U.S players seem to be Precision Instruments, CDI, and Proto. CDI and Precision only make torque equipment. CDI was "recently" purchased by Snap-on and I am going to find out if CDI = Snap-on because CDI is about 60% cheaper.
Craftsman wrenches seem to get very mixed reviews - the "digi tork" model with the "window" seems to be very problematic. The Husky models (Home Despot) seems to get good reviews (for the less expensive models).
My final point - torque values can vary widely based on the condition of the fastener (clean, lubed, etc.) and torque wrenches are not infallible. Use them with that in mind. When you're putting on a wheel and the veins are starting to pop out on your fore head, maybe consider that your torque wrench isn't working correct.
