I remember a similar case on a Chevy truck. By 84 most of the cars had computer controlled systems, but the heavier series trucks/vans still had older style vac/manual engine controls. Those years can have a horrible vacuum line setup depending on emission certs. Some had more than one VSV (vac switch valve), vac delays. Some of the vac valves were thermostatically controlled, especially to distributor advance. If you have any vac leak, a broken plastic housing on any vac valve, or cracked vac delay, you get lean conditions. Some leaks are only apparent after the responsible VSV opens up and exposes the leak.
Long story short, make sure you have no vac leaks before you throw any money at this problem. As c502cid said "Diagnose, don't guess..............."
