Quote:
I assume that having a carburetor means that it is an older vehicle which would likely mean that the fuel system is not sealed as well as a newer vehicle.
Quote:
Use fuel stabilizer on the last fall fill up. I have been using it in my snow blower and havent needed to tear the carb down since.Quote:
Yeah, its for a 70 Camaro with a vented gas cap that could sit a month or more during winter months when the streets have salt on them.
Quote:
Somewhere I remember reading that adding a little acetone will retard separation caused by water contamination of Gasohol.
Good luck Sir.
Rickey.
