How do you decide what weight oil is correct for your engine?
While I wouldn't call my engine, a "race" engine, it should produce 40%-45% more power than stock, so I don't feel that the factory oil recommendations still hold true.
I am still blue printing the engine and don't have the exact piston to cylinder wall clearance or rod oil clearance yet, I do know that my oil clearance for my mains are at .003" which puts them .0001" from the max listed in the factory manual.
My engine is a Toyota 22RE with ported head, header, larger T.B., larger but still mild ([email protected]" x .440") cam, etc.
Power should be around 40 hp per cylinder.
This is going into a 4x4 pickup that will see mostly street but some off road and boat towing.
I am trying to figure out what oil I should run for break in and what I should run after break in.
Thanks for your time.
Ken
Ken
