MolaKule
Staff member
For a suggested starting point, see:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=1;t=007563
I'm waiting for the tests verifying or denying any theories.quote:
MolaKule:
Nice abstract answer.quote:
You're not an automobile engineer with an independent method of verifying lubricant performance, or your car is under a new car warranty and you don't want to play warranty roulette.
quote:
I think the problem is with REDLINE. We have data on this website that shows RL isn't that good of an oil.
quote:
If to compare synthetic oils, according to tests run by our car magazine ester based oils showed considerably higher corrosivity then oils formulated mainly with PAO. To mesure weight loss of metal plates due to corrosion at 9.000 and 15.000 km it was used high temperature oxidation test (1 hour is considered as about 3.000 km). In the same table you will find shear stability. Unfortunately the procedure was not decribed: I could find only that they applied a higher temperature then 100 C (possible they used the same CEC L-14-A-93 with over 100 C and over 30 cycles).
...................................... Corrosion, g ........... Shear stability, %
Motul 300V 5W-30 ............. 7,0 ... 17,8 ............ - 9,0 ... - 3,0
Motul 8100 0W-40 ...................... 16,0 ....................... - 43,3
Shell Helix Ultra 0W-40 .................. 1,8 ....................... - 26,9
Mobil1 0W-40 ............................. 12,0 ...................... - 32,6
Castrol RS 0W-40 ......................... 7,0 ....................... - 49,5
Liqui Moly Synth. 5W-40 ................ 7,1 ....................... - 23,1
Chevron Delo-400 5W-40 ............. 10,0 ....................... - 40,0
Shell Helix Plus 10W-40 ....... 0,1 .... 8,2 .......... - 14,0 ... - 24,0
Castrol GTX5 10W-40 ......... 0,7 .... 3,3 .......... - 11,0 ... - 28,0
BP Visco 3000 10W-40 ........ 0,3 .... 6,0 ........... + 7,2 .... - 4,0
Valvoline Dura Blend ........... 3,7 ... 10,5 .......... - 25,0 ... - 27,0
Esso Ultra 10W-40 ............. 3,2 ... 11,0 .......... - 24,0 ... - 13,0
Castrol GTD 10W-40 ........... 2,0 .... 9,0 .......... - 10,0 ... - 29,0
Shell Helix Super 10W-40 .... 3,2 ... 12,0 .......... - 18,0 ... - 13,0
Liqui Moly Tour. 10W-40 ..... 5,6 ... 19,0 .......... + 12,0 ... + 41,0
MolaKule did, that's how we know wear was nil.quote:
Yeah, tear downs would tell but none of us do that.
To a research chemist.quote:
MolaKule:
I think quoting something from Journals such as Tribology Letters, Lubrication Engineering, Wear, etc would be more meaningful and scientific.
[/QUOTE]
[/QUOTE]quote:
API is funded by whom?
[/QUOTE]quote:
The world views API cert. as a MINIMUM standard.
quote:
And to imply a well bulit oil is lacking simply based on the fact that it doesn't contain API licensing,--- is frankly, ignorant IMO.
Are you calling me ignorant?
quote:
Originally posted by 69 Riv GS:
I think you're the one that posted Dave's response to the low TBN question.
And Terry has explanations for the lead readings.
You don't have to like the product. But, allow others to draw their own conclusions based on ALL the objective facts.
Is that the Exclusive motorsports test? As I recall someone conducting the test is related to a person of power at a major oil company.
Too bad they didn't document their test methods; I find it hard to draw much out of a haphazard test as this appears to be.
quote:
Originally posted by satterfi:
Which API sequence tests for oil/seal compatibility?
Which are?quote:
69 Riv GS:
A statistically significant number of automotive engines operated under realistic conditions, such as the API sequence tests?quote:
