I happened to compare some recent UOA for two oils, 0W-20 Mobil 1 and 0W-20 Fuchs Titan. If you mix these 50-50 you will have a problem. Here is why, and I will use rounded numbers to show the point best.
The major anti-wear, anti-oxidants and others in the M1 include
Moly at 100, Boron 50, Zinc 800 and Ca 2500.
In the Fuchs they are
Moly at 0, Boron 15, Zinc 75 and Ca 2700.
The mix would be around
Moly at 50, Boron 30, Zinc 425 and Ca 2600.
The Ca would be OK but how does it relate to the other additives now that they are now cut in half? The shift may be OK, bad or maybe good, who knows?
I am not sure what the main players are in the Fuchs product but they are probably cut in half as well. And this is of fresh oil. You should not mix oils. Instead, find the product with the characteristics that matches your needs. You cannot do a self induced blend that can better an original product. And severe deficits may occur with your NEW formulation. OR, you could get lucky.
Do you feel lucky today?
aehaas
Ref:
http://theoildrop.server101.com/forums/s...;gonew=1#UNREAD
http://theoildrop.server101.com/forums/s...ge=6#Post800855
aehaas
Ref:
