my 97 dodge ram 2500 cummins diesel truck needs new tyres in the rear. the current tyres which are michelin xps rib are aewsome tyres, i dont have a single complaint on them.
http://www.michelinman.com/construction/xps_rib/30.html
but they are expensive, at $230 a piece from walmart. they are a heavy truck tyre with a load range E (over 3000lbs per tyre at 80psi.)
i was looking around on ebay and found a set of geo-trac load range E tyres in my size that has comparible specs to the michelnis. the only questionable problem was they were made in china, but the price of $80 each was too good to pass up. i made an order and installed them myself.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=66474&item=260092951498
finst impression were that the sidewalls seemed thinner and more flexible compared to the michelins but maybe that is because my michelins are old. driving around with no trailer and no load in the bed, the tyres were fantastic. once i added a load of a 500lb motorcycle in the bed, all the sudden the truck wanders all over the highway and i had to adtively fight to keep it tracking straight. it felt like a tractor trailer was continuely passing me and blowing me around. so i jacked up the air pressure to the max on the sidewall (80psi). this helped out some but i still had to fight the truck. i didnt feel safe going over 55mph. when i added my 7000lb gvwr (1700lb actual) car hauling trailer and a (2900lbs actual) car to the load, i didnt feel safe going over 45mph because the truck wanted to violently go off the road or into oncomming traffic.
with my old michenlins i could do 85-90 all day long with this same load, and using a lesser tyre pressure to boot. so tomorrow i am going to walmart to buy $500 worth of rear tyres for my truck.
i called the chinese tyre dealer today and i got the run around from the salesman. i told him im not interested in a changeout, i just want a refund. they are suppose to call me back before 4:30. if i dont get a call back within 2 days ill issue a chargeback with visa. no big deal because visa will take care of me.
but my lesson is learned about buying chinese tyres.
these things felt like bias ply!
hey maybe they were?
