Do you check the coolant level when the car is cold, warm, or hot? I notice the level could vary so much that when the engine is hot it would be at the full level and when the engine is cool it's slightly below and then when the engine is cold it's below the fill line.
Why? I understand pressure builds up as the liquid heats up but does it also expand in volume? So does car need more coolant?
