I have myself a '04 Rubicon
Stroked the 4.0L to a 4.6L. I ran Chevron 10w30 for break-in, Purolator or Napa filters, and once I reached 10,000km's I'm running Amsoil 10w30 with a large Donaldson filter for surface area and increased crankcase capacity, which is now 7 quarts a change.
The motor is balanced/blueprinted, professionally built, no corners cut. I do believe I'm using a great oil, the group IV 10w30, not the XL, but I wasn't sure if a 10w30 grade would be the best for me. Many have said I need to run a 10w40 since it's a 270hp plus "performance straight 6", I don't particularly want to since thicker oil takes more to pump which creates less milage and a static hp loss (if I'm using the right terminology here).
If I did change grades it would be Amsoil again, but not sure which Amsoil 10w40 would be the best for me.
Also, I have the Amsoil by-pass system on the shelf waiting to go in, with the monster 4 quart bypass filter. I plan on doing a UOA soon to see how things are working out.
So, what do you guys think, is a 10w30 fine, should I run a thicker 10w40?
