Here's another one. Look at the pour point! It could be used outdoors in Minnesota!
Look Pablo, it even has the 4-ball wear test!
AL-SEW-1-2/00
AMERILUBE - SEWING MACHINE OIL is a super premium, synthetic fluid with an advanced technology additive system. It is blended from the finest materials available and has been proven in countless hours of service in virtually every type of equipment. It is odorless and NON-STAINING.
AMERILUBE - SEWING MACHINE OIL gives outstanding service, even in the most severe operating conditions.
Viscosity Index 121
Viscosity cSt @ 40 13
Viscosity cSt @ 100C 3.2
Viscosity SUS @ 100C 69.45
Viscosity SUS @ 212 36.85
Flash Point 320F
Auto-Ignition Point 610
Pour Point -20
Four Ball, 40 Kg, 1200 RPM, 167
1 Hr, Scar Dia mm .48
Four Ball Weld Point, Kg 60
Copper Corrosion, 24 Hr 1a
Demulsibility, 130 40/40/40
Lubricant Designation
SEWING MACHINE OIL
Long Fluid Life Extremely High Film Strength
Excellent Rust Control Excellent Coolant Properties
Carbon & Varnish Control Good Dispersant Properties
Energy Savings
Reduced Maintenance Costs
Reduced Downtime
Reduced Lubricant Consumption
Reduced Misting
Outstanding Oxidation Stability
High Viscosity Index
High Flash & Auto Ignition Points
Very Low Volatility
