1993 Chevy 6.5L turbo diesel
engine is a 2000 model, factory GM replacement
mechanical pump
Oil was in Jan 06 to Nov 06
SDF32 oil filter, not sure on air filter
9,138 miles on oil
64,059 total miles on 2000 model engine.
2.5qts makeup oil
Mix of city and highway driving
BlackStone Labs report
universal averages in ( )
Aluminum......2 (2)
Chromium......1 (2)
Iron............34 (45)
Copper........3 (2)
Lead............11 (10)
Tin..............0 (1)
Molybdenum....3 (21)
Nickel...........0 (1)
Manganese.....0 (0)
Silver............0 (0)
Titanium........0 (0)
Potassium.......0 (0)
Boron...........1 (71)
Silicon.........26 (11)
Sodium..........3 (7)
Calcium.........4082 (3374)
Magnesium.......13 (98)
Phosphorus.....1128 (1112)
Zinc............1385 (1326)
Barium...........0 (1)
Viscosity (cSt) 78.5 (normal SAE 40w)
Flash Point F >410... 470
Fuel% Coolant% 0
Water% 0
Insolubles% TBN 7.0
This is a friend that is in the Air Force with me and is from Ohio. He has made various trips back to Ohio with the truck over the past year. Then local driving to and from work, some stop and go with a few country road miles. Eastern North Carolina climate. I have posted a few reports and read up on here some and from what I can tell this isn't a bad report. The truck had a new factory GM 6.5L installed in 2000 and is a mechanical set up. It runs strong. No problems with the engine that he has told me since it was installed other than an oil leak way before he installed the AME, warranty fixed that. Comments welcome.
mechanical pump
9,138 miles on oil
2.5qts makeup oil
Aluminum......2 (2)
Chromium......1 (2)
Copper........3 (2)
Manganese.....0 (0)
Fuel% Coolant% 0
Water% 0
Insolubles% TBN 7.0
