I'm just kicking this idea around for now to get some ideas and educate myself. My truck is a 98 Ranger. It's 2wd, automatic with the 2.5L 4banger. Pretty simple truck for the most part. For awhile I've kept in the back of my mind of swapping a 302 in there. Since my truck is a 98, I was thinking I could find like a 96-97 V8 Explorer and use those motors. From reading other forums, the 96-97 V8 Explorer models are a pretty straight forward swap as the Ranger and Explorer are on the same chassis design overall making the swap easier to do.
Now the details. Would it be ok to keep the stock rearend or would I have to change to a 9" say?? I have the 8.8 rearend right now running 3:08 gears I'm 80& sure there 3:08's anyway. It might be lower(numerically higher) because I have 15" tires on there and the engine does about 2450RPM @ 60mph in OD. Like I said, I'm not fully sure what's out back. I'm pretty sure I'm running the A4LE tranny. Would it be ok to keep this tranny or swap out to something like a C6? My thinking is If I were to go with the Explorer engine, I can swap the engine and tranny all together without ever having to unbolt the tranny from the Explorer engine. Am I right so far?? Back to engines, I want a good size cam in there for that famous "big cam sound" know what I mean?? that sound is just purely sweet. What size cam will I need as far as degrees in duration and lift, I don't know to be honest.
I would like to ask if you guys can start me out by giving me some websites to check out I can research this subject as far as ballpark pricing, what parts I need. I know this post is lengthy but just thought I would share what I know so far. Thanks,,,,,,AR
