From the New Jersey Department of Health and Senior Services:
"Benzoic Acid is a white crystalline (sand-like) or flaky solid. It
is used as a
plasticizer [emphasis mine], in food preservatives, and in tobacco manufacturing."
Unfamiliar with benzoic acid? It's found in its hydrated sodium salt (sodium benzoate) configuration as used as an extended life corrosion inhibitor in several popular antifreeze coolants including Toyota Antifreeze/Coolant, various Peak antifreeze/coolants, and various antifreeze/coolants marketed by Valvoline and Zerex including Zerex
G-05.
Now, for a few words from Sunoco Chemicals about neodecanoic acid (used as the hydrated salt form (sodium neodecanoate) in the reformulated Prestone extended life antifreeze/coolant, the Prestone "Fully GM Approved DEX-COOL Compatible" extended life antifreeze/coolant, and the SuperTech extended life antifreeze/coolant along with 2-EHA in its hydrated sodium salt (sodium 2-ethyl hexanoate):
"What is Nonene?
Nonene is a branched olefin produced by the polymerization of propylene. It is also commonly referred to as propylene trimer. It is used in the production of nonylphenol, isodecyl alcohol and
neodecanoic acid, which in turn are used to produce
plasticizers, surfactants, lubricating oil additives, polymerization modifiers and paint driers."
The commonality of these acids is that they are
all carboxalic acids, they are
all used in extended life antifreeze/coolants worldwide, and they are
all used as or implicated in the production of plasticisers and other compounds. Now, can we get past what was probably originally a misquote, a misunderstanding, or outright misinformation about the alleged "dangers" of 2-EHA?
[ November 02, 2004, 12:13 AM: Message edited by: Ray H ]
