My experience is as RL claims. I.e. 50/50 mix it will reduce temps 8-10F (if over stat temp). It did just that in the factory fill of '01 GTP for the past 20k miles.
that's incredible! I'm glad you have had a good experience with it. I'm paranoid about dexcool because of all the horror stories about the sludge and how would water wetter interact with dexcool. are you going to pour in another bottle? I read on redline website that water wetter is good for 15k milesquote:
I just checked with Redline. Dave at Redline HQ said Waterwetter is compatible with Dexcool and would make about the same improvement as it does with conventional EG coolant mixes.quote:
Originally posted by Cutehumor:
what does everyone think about water wetter? especially in dexcool.
What did you trade it for?quote:
Originally posted by JWRENCH:
I've been using the W/W now for about 12k miles on the wife's '03 Grand am and no problems. I look at it as a beefier additive package for the coolant to help keep water pump seals etc. in good condition.
BTW, the sunfire we had always seemed to creep up to right at the hot mark alot. We told the service dept. about it on two occasions then one day the water pump broke nearly in half at 35k miles. That along with the cluster fogging up when you turn the air on made us decide to trade that POS in soon after that.
that's odd. i know motorcycle racers who have used it for years without problems. i wonder if the type of Al or casting density is different.quote:
Originally posted by Ron-Indy:
I know one Viper owner who found out the hard way via 2 bottles of Water Wetter with distilled water. Engine was unsalvagable due to internal corrosion.
Or electro-chemical reactions. If the block is grounded and at a different potential across the coolant, this could happen.quote:
Originally posted by Michael SR:
that's odd. i know motorcycle racers who have used it for years without problems. i wonder if the type of Al or casting density is different.[/QB]
I heard when you run just water(no coolant) with water wetter that you should change every 3mos.Maybe dude waited 2-3 years.quote:
Water Wetter with water alone will severely corrode an aluminum engine.
