TP4ME
Just wondered if you have any info on the Spinner vs. the MG oil tests?
BTW I have Mg and Spinner II in series. Eveything can go through the MG, but at 35 PSI the Spinner II has fluid thanks to pressure cutoff valve. So theoretically I have all bases covered:
40 psi prelubing, MG up to 35 psi and then, MG + Spinner II after 35 psi.
Mobile 1 15/50
No oil tests as I don't need them. Arrogant? Not if you do the math. No cleaner oil can be had on a vehicle, maybe better thatn new oil.
Also run B100 fuel (low soot) and a paper air filter
Aquaworksllc
