Greetings everyone, this is #1 post for me.
I've owned the above listed Honda since new. The wife drove it all highway for its first 50k miles. I am a freak on maintenance, and changed the oil exactly at the factory-recommended 5k "Severe" interval, using Honda filters and Valvoline 5w20 for the first 30k. I then began using Amsoil 0w30 and their SDF/EA filters after that. (Plus Amsoil ATF at 31k, shifts smooth, no leaks) It uses about 1 quart every 8-10k, which in my opinion is nothing.
Anyways, for the last 5k and on days where the morning temp is lower than 40 degrees, there is a very light valve ticking sound until it completely warms up, and then it goes away. I'm still driving it probably 60/40 highway/street, and still change my oil and filter exactly how Amsoil says to based on mileage or year's end (Always on Jan. 1, told you I'm a freak.) I called the Honda dealer today, and they said not to worry about it because the first scheduled valve adjustments should be made at 105k. I then called a very respected indy shop here in Cincinnati, talking with the shop owner himself, and he said with my 0w30 I most likely don't have anything to worry about. However, he did say it can't hurt to open it up and adjust if necessary before 105k.
I have the shop manual from Honda and could do this myself, I'm just trying to figure out if I actually need to before 105k.
Your thoughts, fellow oil freaks....
