Okay, so I decided to try the water through the PCV system trick on my 87 Honda Accord. I know there is carbon buildup on the pistons.
Anyhow, I took out the PCV valve which is mounted into the intake manifold. One side has a pipe which runs down towards the block, and the other side seems to go towards the carburetor. There should only be vacuum on the intake side of the valve, right?
Anyhow, I hooked up a hose, and put some water in the cup, sat in the car, and held the revs at about 3000 and held the hose at the surface of the water and let the hose just suck up the water. The vacuum was real strong, and it took the water pretty quick. I did 4oz at a time, 4 times total.
I had a piece of plywood propped against the back bumper to catch the spray out the tailpipe. I checked the plywood after each time, and I didn't see any signs of water. I've got a big hole in the exhaust, which I'm fixing now, but I didn't see signs of steam there either.
So I decide to stop, and change the oil since I know that should be done afterwards.
It looks to me like all the water went into the oil. I took the valve cover off and there was signs of water in there. What did I do wrong?
