I have a 99 Quest with the VG33E. Has a strange problem. It feels like the throttle is sticking while driving. If I'm in a traffic jam, everyone else is rolling off the brakes and I'm the only one on the brakes. Same at steady speed cruise, I let go of throttle and vehicle maintains speed like cruise is on.
Park and Neutral, there's no issue. Rev up and it comes down nicely to base idle no problem. Only when driving is there an issue.
I've cleaned out the throttle body, no codes, everything to spec and tune-up done. I have alldata subsription which shows TSB #00-006C date oct.6,2003. 'ECM REPROGRAMMING'. But it doesn't explain why, just the actual service procedure.
Anybody know, had it done, experienced something similar?
thanks.
thanks.
