I'm trying to diagnose a noise problem that I'm experiencing and have been experiencing for at least 2 years (pre camshaft swap, pre intake manifold swap, etc...)
There's a "clack clack" sound that I hear that does not come from anyplace in particular but seems to be concentrated on the top end of the motor near the firewall (4.6L SOHC V8). You can hear it from the wheel well and underneath the engine but its loudest up top, center, and in the back.
I will hear this sound in the cold or hot ambients (0*F to 100*F).
It does not matter if the motor is hot or cold.
The only time I hear it is when idling at 650-850 RPM. As soon as I get on the throttle the sound goes away.
At partial throttle up to WOT, the sound is not "audible".
There's no rattling during the first cold start of the morning.
Anyone have any suggestions on how I can narrow down the search by elimination?
I now have CompCams XE262Hs mounted on my NPI heads.
I also have a revised Ford PI Intake manifold.
The engine is a 2000 4.6L SOHC V8 on a 2000 Crown Vic. I've logged 8000+ miles on the CompCams. The car only has 17,700 miles.
I had been running M1 5W-30 and even tried 10W-30 w/o killing this sound.
I'm now running on some SuperTech synth 5W-30 I had lying around.
It sees drag racing, daily driving, and long distance trips - definitely not a garage queen or trailer queen. If there's 16" of snow, the car is going to mush through it all.
I can try to provide as much extra info as needed.
I was just going to dump 5W-20 and 5W-40 to see if it'd help eliminate the sound.
