I'm in the process of rebuilding my 67' GTO 400 motor. I pulled the transmission which is a GM TurboHydramatic 400, It is a PX series, 2 dimple pan, which was used on late 67' GTO's. Having the tranny gone through by a good transmission shop to do a little "beefing up". My question is: what is the best Mercon 3 ATF fluid to use in this older transmission? I normally use Mobil 1 Synthetic ATF in my newer vehicles but not sure this is the best approach for this older 400 tranny. This auto is a "cruiser" with a 350hp motor and not used a racer. Should I use regular ATF (what brand) or go with a true synthetic?
