I have a 2005 Highlander V6 AWD and I'm curious as to what the consensus is (if any) on when the differential and transfer case fluid should be changed out. And to what? I do not have any reason to believe the Toyota folks are using a full synthetic fluid in these units.
Forget the owner's manual. They're recommending 10 years or 120K on the coolant before changing. Right! Let me schedule that on my calendar for 10 years from now.
It has the towing package (ATF cooler, bigger radiator, heavy-duty alternator, all of which have nothing to do with the diff or transfer case fluids, but I thought that package was worth $160), but I won't be doing in towing.
