darkdan is correct. Jerry Wroblewski, one of the Ford transmission engineers who designed the 4R70W, says that Mercon V is not only acceptable, it's actually preferred, IN THIS TRANSMISSION ONLY. He goes on to caution against using Mercon V in place of Mercon for other applications, specifically mentioning the Taurus as an example.quote:
Originally posted by wavinwayne:
According to the info found here: http://www.fcsdchemicalsandlubricants.com/supplier/quickref.asp using Mercon V in a Mercon application is a big
What say you on the subject, darkdan?
*EDIT* Forgot to include the link.
[ February 03, 2005, 12:15 PM: Message edited by: RF Overlord ]
