quote:
Originally posted by JohnBrowning:
The early Corvettes that came with Muncies had a whale ester based fluid in the transmission and in the rear diff. THe cloest I have found to replicateing this fluid is with Redlines MTL. I have alot of Corvette customers that are very happy with this combination in their Muncie!
Huh!?
Can you provide more details or info on this whale oil GM used specifically in Corvettes?
Corvettes ran Muncies from about '63 or so up til about '74. Which ones are you referring to as early? '63-'67?
What about all the Muncies destined for millions of other GMs besides Corvettes. They didn't get the whale stuff?
GM manuals from 'the day' I'm familiar with simply list "SAE 90 GL5", nothing special.
The MTL is a bit light for a Muncie 4 speed IMHO. I think MT90 might be a better option. But if the Muncie is new or rebuilt or whatever the MTL (or GM Synchromesh) might be worth a shot. If it doesn't leak out, it might produce easier shifting in a Muncie. But the Muncie was originally made for a heavier oil in mind like an MT90 and benefits from a good quality GL4 (like Redline) from what I can tell.
You mentioned that MTL is the closest substitute you found for this purported "
whale ester based fluid ...[used]...in the rear diff." I presume we all know this but it's worth repeating perhaps... MTL is
NOT for differentials and as a GL4 will potentially ruin ring/pinion gear set in short order!
As to this claim of '63-? Corvettes running whale based oils in both their boxes here's my thought on it based on what little I know...
Back in the 60s GM's Positrac additive did contain among other things some element of whale oil I'm told. Whaling has long long ago fallen out of favor. Not sure exaclty when but sometime in the 70s I believe GM finally found a substitute ingredient for their Positrac (limited slip) additive. You can buy their additive at any dealer and it's good stuff. It's one of the better LSD fluids out there and quite popular w/ many car crowds, not just the Chevy types.
Most modern differential oils include a friction modifier for LSDs making such additives unnecessary. If you purchase one that doesn't have it and need an LSD friction modifier, you can use GM's or whoever's separate additive. I suggest sneaking up on it. Add a few ounces at a time to the diffential fluid until all chatter is gone. Most folks report that thigns quite down between about a 1/2 bottle and 1 bottle (2 max, these are VERY tiny bottles last I checked, maybe 6 oz) but as always YMMV.
But again, I don't see much need for that approach. Every modern GL5 oil that states it's for limited slip differentials has always worked fine in LSDs as is w/ no clutch chatter in my limited experience.
The GM additive was and is not specific to early Corvettes and was for any GM sporting an optional 'Positrac' and works fine in any other makers LSD as well. Positrac was not standard on Corvettes until about '70 or so though it was an overwhelmingly popular option by then.
This GM additive has
nothing to do w/ Muncie 4 speeds.
