http://ngkaz.home.att.net/wsb/html/view.cgi-home.html-.html
download the 2Mb ngk cross reference matrix, it is an excel file.
It has all spark plug cross references.
4053 comes up under autolite, 14mm thread, gasket type seal (as opposed to tapered), 0.75" reach, .8125 (13/16)" hex size. technically, all you need is a plug with 14mm threads and no longer than .75" reach, and close enough heat range- possibly one higher if it's 2-cycle and you run it rich or the plug is tyically sooted up.
some cross refs I can see are:
ngk stock 2411 (B8ES) $1.71
ngk stock 2984, (R5686-8) $22.34
ngk stock 3923, (BPR8ES) $1.80
bosch 7530, 7529* (W4CC, W3CC*) *hotter
Champ 805 (N2C)
Champ 801 (N3C) *hotter
Champ 693 (C55)
Champ 686 (C57) *hotter
Champ 904 (RN4YC)
I'm fairly certain I've seen Champion lawn & garden plugs in walmart and the like stores with #801 or 805,
but any self-respecting bitoger would mail order the R5686-8 and some synthetic Redline/Amsoil/Motul 2-cycle oil
