quote:
The John Deere L series was developed as a low end machine to sell at Home Depot. They are also available for the same price, at John Deere Dealers. Being a Service Manager at a dealership, I know what is and is not durable. If you have a small yard, you will be ok with this purchase, otherwise,you won't. I see more of these back than any other machine Deere makes.
First, the features- the twin cylinder Briggs engine has plenty enough power to pull the machine around- but, when you have to change the oil filter it is no fun to get to. This machine has a seperate choke and throttle lever-you'll need them both as the engine is cold-natured. Once warmed up, (takes just a bit.)the engine runs well. The
controls are easy to understand, one pedal for forward, one for reverse. I must tell you that if you have a hilly yard, you will find that the transaxle is weak- it is not as strong or fast as other Deeres. There is a cruise feature as well, handy for long areas. This machine does not turn as sharply as other Deeres,Not even as well as
some MTD mowers. the front axle is cast iron, with grease fittings on each front spindle, and on each wheel. This is because the wheels ride on bushings, instead of bearings as in the lt lx and gt mowers. The mowing deck is engaged by an electric clutch- this is a nice feature and reduces wear on the belt.
THe deck itself has been the source of several problems. The deck spindles (the part the blade bolts to) are made of aluminum with non greasable bearings- ordinarily, this would not be a problem- but I have seen several failures, due to inferior bearings. The replacement spindles, should you need to buy one, are about 38 dollars each- and are greasable. These seem to be holding up better.Adjusting the deck height is easy enough, with an easy to use fender mounted lever.
The L series mowers use pushnuts and self tapping bolts to assemble the machine- which may be a great time saver, but not a good idea from a service/durability standpoint. Refueling requires raising the seat and hitting a small filler hole- other models( Lt,Lx,Gx, and Gt) have the nice, large filler neck, on the left fender, where it
belongs.
This is not a quiet mower, the hydrostatic drive on these whines, even when new, and there is a decent muffler on the engine, but not what Deere is known for. One thing they did get right is the hood- it is made of a polymer like all Deere hoods on lawnmowers. The hood on the L-series, however, seems to be more durable, and less likely to crack.
The thing to remember here is that this is a low end, loss leader machine- designed to compete on that level with other discount store offerings. While the welded frame and durable hood are nice, they don't make it a deal. The l is the lowest rung on the Deere ladder- the next rung up is the LT,(I own one) and it is a good machine- next up is the LX, then the GT, and GX. If you have a
small yard , this machine is fine- if you have a lot of things to mow around, or a large yard- step up or look elsewhere.
Recommended = NO
